Weird revving issue and bike wont idle
Hi all,
I bought my Fazer a while ago, it had been standing for ages.
there was a fair bit wrong with it but I've sorted most things out.
There are 2 problems, not sure if they are related.
The bike doesnt like to idle, with the choke it's fine, without it'll idle for a  few secs then sounds like it's gonna die, a few more secs and it usually does. The idle screw is as high as it will go. also if I pull the clutch in when I've got the choke on, then it revs loads (at about 5000 rpm)
So thats issue number one.
The second issue is when I'm riding along, If I slam open the throttle, the revs jump up high and then jump back down to where they should be and then the bike will accelerate. If I roll the throttle open real slow it doesn't happen, but as soon as I give it some it jumps. It doesnt matter where in the rev range I am or what gear I'm in it always happens, it's almost like I'm in neutral for a sec, then goes back to normal. Recently changed the chain and sprockets but it was doing this before that too.
Not sure where to start.
Any ideas?
Thanks
Hello, I think if the bike has been left for a while I would put some new fresh fuel in and that may help it to idle. If you have already done that, then I would check the condition of the spark plugs next as you may get a clue as to what's causing the problem. Your other problem sounds like the clutch is slipping so it could be worn plates or incorrectly adjusted either at the lever or in the front sprocket cover end. It's easy to re adjust, I would start there before taking anything apart. Others with lots more knowledge will give more help soon no doubt, good luck!  Smile
Second issues is as yamazer says is clutch related. Wrongly adjusted at the sprocket cover or worn friction plates
First one sounds like pilot jets blocked or wrongly adjusted pilot screws.
The 02 -03 models have different pilot screw adjustments to the earlier models. They should be 2.5 turns out from fully in.
If you replaced or cleaned the jets then it is most likely the pilot screws
Remove the carbs and check the pilot jets and the setting of the pilot screws.
It is possible to get at the screws with a special tool with the carbs in place, but if you do not have it then it is carbs off
(04-01-15, 09:51 PM)Yamazer-92 link Wrote: Hello, I think if the bike has been left for a while I would put some new fresh fuel in and that may help it to idle. If you have already done that, then I would check the condition of the spark plugs next as you may get a clue as to what's causing the problem. Your other problem sounds like the clutch is slipping so it could be worn plates or incorrectly adjusted either at the lever or in the front sprocket cover end. It's easy to re adjust, I would start there before taking anything apart. Others with lots more knowledge will give more help soon no doubt, good luck!  Smile
Hiya, thanks for the reply, I've put in plenty of fresh fuel since I've had it, been using premium stuff to see if that made a difference but no joy.
Brand new spark plugs.
Will definitely play with the adjustment on the Cluth cable to see if that helps. Does it sound like it needs slackening or tightening?
Thanks
What oil is in there?
I'm just wondering because from the rise in revs when you pull the clutch in when idling in neutral it sounds as though the gearbox might be giving a lot of drag. If someone's put a thick gearbox oil in there instead of engine oil that would account for it. It'd also cause massive clutch slip when under way.
(04-01-15, 11:22 PM)unfazed link Wrote: Second issues is as yamazer says is clutch related. Wrongly adjusted at the sprocket cover or worn friction plates
Hiya,
Will definitely check the cable slack at the lever and sprocket. Does it sound like it needs tightening or loosening?
I thought the 1st issue might be carb related, just because it had been sat for so long. Sorry to sound daft, but where are the pilot screws on these carbs? Are they underneath?
Thanks
(05-01-15, 12:58 PM)Fazerider link Wrote: What oil is in there?
Hi,
Thanks for the reply.
I changed the oil recently. I used Silkolene Super 4.
Thanks
Slacken the cable a bit. If there's too much tension on the cable from being adjusted too tight it's as if you've got the lever slightly pulled all the time so it slips. Do you have to release the lever quite far before it engages? That would be another tell tale sign that it's adjusted too tight. It could also be worn clutch plates or old oil but it's probably just the cable needs to be adjusted.
Sounds like it's not getting enough petrol at idle as the lads said. If it only runs ok with the choke pulled then it's probably not getting enough fuel at idle so that points to blocked pilot jets. Turning the idle screw all the way in is probably making it worst not helping because that opens the butterfly valve so you'd be getting more air when you need more fuel not more air. If it's been parked up for a good while then a good carb clean and put the idle screw back to normal and it should sort it.
(05-01-15, 01:19 PM)His Dudeness link Wrote: Slacken the cable a bit. If there's too much tension on the cable from being adjusted too tight it's as if you've got the lever slightly pulled all the time so it slips. Do you have to release the lever quite far before it engages? That would be another tell tale sign that it's adjusted too tight. It could also be worn clutch plates or old oil but it's probably just the cable needs to be adjusted.
Hi Dudeness,
Will definitely slacken the cable to see if that makes a difference.
The bite point is far out. I hardly have to touch the lever to reach the bite point.
I turned the idle all the way out, because until I did that, it didnt idle at all, not even for the small amount of time that it does now, but I'll definitely check that again.
Are the pilot screws on the bottom of the carbs or are they on the side? Also to set them correctly, would it be 2.5 turns clockwise or anti clockwise?
Thanks
Unfortunately at the bottom,
Turn them anticlockwise one full turn first to ensure they are not stuck or already at the stop point.
Now Turn them clockwise until they stop, don't force them past the stop point or you will damage the seating.  Mark where they stop on the edge in line with the screwdriver slot, make it easier to set the number of turns.
Now turn them anticlockwise 2.5 turns.
Make sure the screwdriver fits the slot properly
(05-01-15, 03:23 PM)unfazed link Wrote: Unfortunately at the bottom,
Thanks Unfazed!
I'll give that a bash when I'm off work next.
Using the bike to commute at the mo.
You reckon I'll be able to reach all 4 without taking the carbs off?
Thanks again.
Unless you have access to the special tool it is a carbs off job. :'(
You will not have to remove them completely, you could leave the throttle cables attached and lift the carbs up through the frame enough to get at the screws.
Are you sure the pilot jets are clean?
(05-01-15, 07:09 PM)unfazed link Wrote: Unless you have access to the special tool it is a carbs off job. :'(
Hiya,
Not sure at all.
In fact as it was standing it's likely that they are fouled, though I did put some Redex in the tank to try and clean them a bit coz the instructions said that it should clean carbs.
But this made no difference. Also, do you have a pic or link to the tool you're talking about?
Thanks again
Access to the idle screws is not really that bad. A short screwdriver bit from a 1/4" ratchet set will do, the only carb which is awkward is number 3, but you can get to it by pulling the starter motor out of the way.
Hiya guys,
Quick update, I adjusted the clutch at the sprocket (by the way, the way you adjust the clutch there is a bit odd, I thought I'd be loosening and tightening nuts on the cable itself, not on the sprocket cover?!) This has solved the revving issue, so a big thanks for that Smile.
Just gotta wait for this weather to calm down a bit and I'll check out the carb settings.
I'll let  you know how I get on.
Thanks again!
Hi again,
Further update.
Took the carbs off to day, They were pretty rank.
Took them to have an ultra-sonic clean.
Will let you all know if it sorts the issue.
Also I'm dreading putting them back on, they were a bitch to get off! the throttle cable were a night mare!
Any tips for putting it back together?
Fit the cables to the carbs before fitting carbs to the bike, making sure the throttle snaps back before re fitting.....tip no2........plenty of tea and take your time    :thumbup
With the air box pulled right back tighten the 2 side bolts to stop the air box moving while try to get the carbs in place. Moisten a cloth with WD40 and rub it on to the edge and inside of the rubbers before you you start the fitting. Makes it easier to fit the carbs into the rubbers.
Loosen the the hose clips until the bolt is flush with the nut. Any less and they will be to tight to push the carbs on.
Keep checking that nothing is in the way as you feed them back in between the rubbers.
You will need three hands to get one of the cables on  :lol . I usually jam the throttle open full to put that one on it makes it easier, just make sure to feed them through correctly. Nothing worse than having the cable on only to find it is in the wrong way. :'(
Enjoy Smile
And as Red says plenty of time and cups of tea  :thumbup
(10-01-15, 07:15 PM)red98 link Wrote: Fit the cables to the carbs before fitting carbs to the bike, making sure the throttle snaps back before re fitting.....tip no2........plenty of tea and take your time    :thumbup
Cheers mate. Solid advice Smile
(10-01-15, 08:51 PM)unfazed link Wrote: With the air box pulled right back tighten the 2 side bolts to stop the air box moving while try to get the carbs in place. Moisten a cloth with WD40 and rub it on to the edge and inside of the rubbers before you you start the fitting. Makes it easier to fit the carbs into the rubbers.
Enjoy Smile
Thanks Unfazed!
Good idea about tightening the screws on the air box to keep it back.
Wish I thought of that trying to get them out.
Also good tip about the WD40 too
Thanks again Smile
