What should my voltmeter read direct across the battery with the engine running alone and then with full beam?
I know most cars run ~14v with the engine running and not less than 13v with full load, should a Fazer be about the same?
Just think how stupid the "average" person is. Isn't it a worry that statistically approximately 50% of the population are thicker!
(03-01-15, 06:05 AM)Fazafou link Wrote: I have a little voltmeter fitted (few quid from China) and so its easy to check the state of the battery before firing her up and then the generator once on the move
Have you got any details on this?
True, and is technically better, but a bit overkill for a simple cheap voltmeter.
Mine off the sidelights is about 0.3 volts difference to the actual battery, which is fine to indicate issues and I know the offset either way. I can live with that error and save the hassle of wiring in a relay.
Ideal if you have a live off a relay already plumbed in though.
