Instrument Panel
Noticed on Friday my LCD instrument panel was loose on the FZ6, expect a bit of movement being mounted on rubbers so had enough of the front end off today to have a look and managed to get a long screwdriver in by the headlights to reach up under the panel and one screw was loose so done it up but still a bit of movement which is when I noticed a couple of plastic poles coming off the bottom of the panel and going through holes on the metal plate that the panel fits too. I'm presuming that there should be grommets in these as that is where the movement seems to be but both sides are missing, if there is does anyone know what size grommet it is for the hole?
Of course the next adventure will be working out how to get them on there without having to take most of the front end off  Wink
[Image: 07fz6_red_7b_2cece3a0.jpg]
Thanks for any info
(03-11-14, 11:15 PM)Devic link Wrote: Noticed on Friday my LCD instrument panel was loose on the FZ6, expect a bit of movement being mounted on rubbers so had enough of the front end off today to have a look and managed to get a long screwdriver in by the headlights to reach up under the panel and one screw was loose so done it up but still a bit of movement which is when I noticed a couple of plastic poles coming off the bottom of the panel and going through holes on the metal plate that the panel fits too. I'm presuming that there should be grommets in these as that is where the movement seems to be but both sides are missing, if there is does anyone know what size grommet it is for the hole?
Thanks for any info
Just take the fairing and headlight off mate, it'll be a lot quicker than fannying around for hours!
