I'm now in possession of an R6 shock, supplied and modified by kebab19, many thanks to him for that and what a lovely looking thing it is too. As my chain and sprockets are at the end of their life I thought I would take this chance to strip out, clean and overhaul the rear end.[smg id=2322 type=preview align=center caption="IMAG0485"] I removed front sprocket engine cover, chain fling, so much chain fling every where so I set to with a shovel, an hour or so later and I've found crank cases, another hour and it's as clean as I can get it.[smg id=2323 type=preview align=center caption="IMAG0456"][smg id=2324 type=preview align=center caption="IMAG0458"]
Now check front sprocket nut and it's the old type but luckily it is tight and in good Nick but will still be replaced for thicker one.[smg id=2325 type=preview align=center caption="IMAG0464"]
Sprocket teeth have looked better.[smg id=2326 type=preview align=center caption="IMAG0463"]
Splines looking good. Back wheel out next then undo linkage and remove and amazingly it looks well greased and bearings are in good nick so just regrease needed there. Next swing arm bolt, worryingly not very tight, removed rear brake and torque arm and caliper then dropped the swing arm out rear shock next and yuck.[smg id=2327 type=preview align=center caption="IMAG0465"][smg id=2328 type=preview align=center caption="IMAG0467"]
Set to with the degreaser and scrubbing brush.[smg id=2329 type=preview align=center caption="IMAG0487"][smg id=2330 type=preview align=center caption="IMAG0488"][smg id=2331 type=preview align=center caption="2014 10 26 15 19 46"]
Well that's as far as I can go untill New chain and sprockets arrive, should be midweek so will be putting back together next weekend so tune in then for next episode.
There ain't arf been some clever bastards
loving this,im getting a shock off kebab and so will be doing this myself (ok,getting my mate to do the spanner work,i'll just be de greasing everything !! )
did you take a picture off the gear linkage,so i know what to expect?
i de greased the front sprocket area when we changed the old nut to the new better one,will no dought have to do it again though....
look forward to the next part :thumbup
looking much better already! Keep the pics coming! 8)
Chris
![[Image: 208008.png]](http://badges.fuelly.com/images/smallsig-uk/208008.png)
Before refitting the rear frame fit the shock on it's top bolt. I found it much easier lifting the frame up to it than fighting to fit the shock up through the frame
including ones who like chocolate....
[smg id=2332 type=preview align=center caption="IMAG0486"] That's one grotty looking thing removed and a nice shiny looking thing waiting to take its place.
More shiny stuff arrived, New chain and sprockets and I popped into wemoto and picked up a new front sprocket nut and tab washer. [smg id=2336 type=preview align=center caption="IMAG0503"] That's everything sorted for the rebuild and all the bearings are now greased up ready to go back on. All I need is some good weather at the weekend and the forecast is looking good, fingers crossed for Saturday.
Sun is shining so good day to rebuild the old girl. As suggested by midden, shock in first then feed shock though swing arm as I offer it up to its mountings, not forgetting to thread the chain on to swing arm beforehand, so much easier than trying to pass the fat end of the R6 shock through a small hole, pivot bolt in and torqued up. On with the linkage parts and dog bones, which look really nice, all torqued up to Haynes quoted ratings (hope they got these ones right). Front sprocket on next on with the new nut and tab washer, thread chain on to sprocket, rear sprocket fixed to carrier with stainless nuts ( I didn't use any old nuts to be on the safe side I used pro bolt stainless Sprocket nuts), back wheel in and it's mostly back together.[smg id=2339 type=preview align=center caption="IMAG0505"] [smg id=2340 type=preview align=center caption="IMAG0504"] Front sprocket cover back on, adjust chain tention and wheel alignment chain guard and done. I checked all nuts and bolts to make sure I didn't miss any and all is how it should be and tight. Next take it for a spin.
Back form test ride and wow, grin factor is back, she goes round corners again without trying to kill me and much smoother feel, so pleased with that. I haven't done anything to the shock, the settings are as they were when kebab19 sent it to me and it's 100% better already. I would be grateful for any suggestions as to set up from any foccers who have got one of these lovely shocks.[smg id=2341 type=preview align=center caption="IMAG0508"] [smg id=2342 type=preview align=center caption="IMAG0507"] gear linkage photo as requested, not quite sure what it is you were not sure of, if you can be more specific as to what you wanted to see I might have a pic of it.[smg id=2343 type=preview align=center caption="IMAG0509"]
thanks for the picture of the gear linkage that i asked for,i was curious to see where the bearings/spacers would be as neon knight mentioned elsewhere that his were shot when he replaced his rear shock, so im keen not to find mine are bad as and when i get round to fitting my R6 shock from kebab19, as i wont be able to leave the bike in the middle of my mates 2 ramp garage as it'll be in the way of his job while i wait for the new parts to arrive,if needed.
i think that explains myself,clear as mud eh?!! :lol
bike looks good by the way :thumbup
(02-11-14, 06:54 PM)pilgo link Wrote: thanks for the picture of the gear linkage that i asked for,i was curious to see where the bearings/spacers would be as neon knight mentioned elsewhere that his were shot when he replaced his rear shock, so im keen not to find mine are bad as and when i get round to fitting my R6 shock from kebab19, as i wont be able to leave the bike in the middle of my mates 2 ramp garage as it'll be in the way of his job while i wait for the new parts to arrive,if needed.
bike looks good by the way :thumbup It's the suspension linkage you're after not gear link
(02-11-14, 11:09 PM)midden link Wrote: [quote author=pilgo link=topic=15125.msg172116#msg172116 date=1414950860]
well spotted,my deliberate mistake :lol
Haha, the only bit I didn't take a picture of don't panic though, when you remove it, removed the 3 bolts securing it to the frame, shock and dog bones and the whole thing comes away intact. Check spacers for free pay, slide them out and check bearing needle bearings, ideally you will see greased rollers securely held in a cage. If any of them need replacing, they can be tapped out but must be pulled back in, tapping them in will damage them. If your unsure of what your looking at when you do put a lovely R6 shock on your bike and you've got the linkage in your hand pop some pics on here and I'm sure help will follow[smg id=2345 type=preview align=center caption="2014 11 03 17 41 08"] Hope this helps.
great,quick update mate,thanks :thumbup
i looked it up on the AJ SUTTON site, who use similar pictures to the one you posted from the Haynes manual,so i kind of know what im looking at as and when it gets fitted
fingers x'd they are ok, the joys of having to get it done on the day,rather than being able to leave it in bits while you wait for new parts to arrive eh?!!
