Think these get fitted to take some of the "slop" out of the gear change as it is a shorter unit. Think that it rubs a little on the frame, but not 100% sure.
It's the early R1 gear shift arm that gets fitted to shorten the gear change, not the gear lever, sorry but no idea if the item in the link you have posted will fit.
hi lee,
I have one for the gen1 , £ 20 posted, if you are interested pm me
Anyone is selling one of the sift arms? Looking for one at a reasonable price and couldntt find one
24-04-23, 10:12 AM
(This post was last modified: 29-07-23, 01:14 PM by Gaz66.)
Hi ...
Early R1 gear change lever won't fit a Fazer 1000 which is a shame as it's a better design, upper shift arm will fit giving a shorter lever throw.
Fazer 1000 lever shift throw is on the long side, had one in the garage a few yrs, fitted it now & seams to improve gear selection a bit.
Shift rod needed a slight "S" bend to clear the frame rail it runs thru, I just set lever height where I wanted it, measured it from the floor while on centre stand, marked where top of rod is with a sharpie, took rod off again & put as a slight "S" bend in it & refitted.
Yamaha gear boxes aren't in the same class as Honda, very clunky/agricultural shifting from my experience, never owned a new Yamaha only used, so could be down to rough use from previous owners.
Link rod will foul the frame a bit, so will need persuading a bit.
Rarely see em for sale used & new price is crazy expensive.
I've had one on my bike for many years. i found it much more precise. You do need to adjust the rod that connects the foot pedal to the shifter arm. A little bend sorts that though.
Awesome thread revival from 2014 ??
