Nasty looking washers mate. F**k them off and bung a k and n air filter on the bike while you're at it. +1 to what paulfzs said.
Thanks, it was restricted yeah to 33bhp..Washers werent there. Found out in a older topic where it doesnt go over 8rpm in 6th and stays the same speed , that the Needles might be different from the original ones.Going to check it out tomorrow.Or maybe now.
Yeah i did check them.Werent there. Maybe any1 can tell me what`s written on your needles ( upper carb part where diaphragms are) Mines has 5D92 , not sure if the needle is right. Cant get any1 to show me the proper one, maybe it`s restricted with the needle as it was said in some ealrier topic.
Hi egidijs....welcome to the forum, just checked the yamaha service information book and it says jet needle should be 5D86....this could be where your bike is restricted...
Me again....just been digging for more info....you do indeed have the restricted jet needles.to confirm this there should also be a metal plate beneath the diaphram, fits over the flat part of the slider....to regain full power you need to fit the correct needle ,5D86, remove the metal plate and also fit the correct spring, the one you have will be a bit stiffer....might be worth posting a wanted ad in the for sale section to see if anyone has the parts.......
08-09-14, 08:27 PM
(This post was last modified: 08-09-14, 08:30 PM by Egidijs.)
I might get a hand of 3 needles ( i know a person who might have em) well as for the springs, just cut down some rolls heh..or i`ll ask him for them too .Might just figure something out.
There was a metal plate (which i removed) , there were no diaphragms for the starters ( which i got now) but the power didnt change ,maybe slightly.So now we found out about the needles..I might get the proper spirngs also.
You might have to change the height of the needle as well.....cant remember what they should be on, I'll see kif I can find out for you.......cutting the springs down will cause allsorts of running problems, best to use the right ones..........those markings on the jet needles ard hard to see....or is it my old eyes :lol..........where you from ?.....post in the intro section and tell us a bit about yourself....oh....and we do like pictures.......
The needles should be on 3rd mark (from the top) when i applied the diaphragms, the carb was running too rich (even using default carb fuel intake modification 2spins) , so i lowered the needle to 2nd gap, runs almost smooth. Before that it was kinda gagging and vibrating when i`m giving full throtle. Yeah i was too excited to get all the needed information and reading havent had time to config my profile. I`m from Latvia btw.
Just noticed your wanted ad...hope someones got the parts you need, you'll be impressed at the full power these bikes have...great fun
I hope i`ll get to use it since the season is ending soon ( less than a month) :\
