I've been reading that to get the cam chain tensioner to advance the last few clicks, you can try rolling the bike back in gear with the plugs out to get the chain to slacken off so the tensioner can click.
My question is, why do you need to remove the plugs to do this? Also, I'm buggered if I can get the bike to roll backwards in gear with my puny strength!
You roll the bike back in gear with the clutch lever held in........then let the lever go and it will give the bike a jolt.
03-09-14, 09:07 AM
(This post was last modified: 03-09-14, 09:15 AM by Fazerider.)
What gear were you in when you tried? Obviously the higher the gear, the easier it is for the wheel to drive the engine.
I don't see why an increase in cam chain tension at the back should encourage the tensioner to tighten, but if people say it works then I guess it does.
>edit<
Ooops, too early in the morning for logical thought... rotation's the wrong way, but yes, the tension is going to be at the front run of the chain.
If you don't fancy taking the plugs out, then:
Ride it part way up a steep (ish) hill, turn the engine off, put it in a high gear and let gravity help you.
