Gen 1 & Gen 2 Exup Motor
Does anyone know if the Gen1 and Gen2 exup valve motors are the same....mine is still playing up and I've seen a picture of one at a local breaker that looks very similar.....for £30 its well worth it.
Can you remove the servo from the bracket so we can see the mounting points..
There seems to a screw missing from this one in the number 2 marking......haven't a clue what that would be for......this apparently came off a 2004 fuel injection model.....I thought fuel injection was only on the Gen2 and came out in 2006
they have very different part no's and prices..................so i'm gonna say no way, jose!
Now fitted........the boys at Dynotech Ecosse did a brilliant job......had to do a bit with the dremel to get the rubber mounting to fit but its working perfectly......put it on the dyno and showing 134bhp at the back wheel and smooth curves all the way....fuelling is perfect too.
So what your saying is if and when my ex up packs in I should be giving them a shout? Smile
(31-07-14, 05:32 PM)mickvp link Wrote: So what your saying is if and when my ex up packs in I should be giving them a shout? Smile
Mick, these guys are top mechanics and have done quite a lot of work on my Fazer, so not just the exup they can do pretty much everything....also have a dyno set up so you can see the improvements when you get the full monty done.
