Hi recently done the fork seals and on rebuilding the forks ive notice oil weeping from the top nut.. does anyone know the oring size its the one that seals the stantion to the top nut.. and where to get them or is it going to be a trip to the stealers? Its a gen1
fork top o ring
22-07-14, 07:12 PM
Unless you can find a motor factors that will sell o rings loose, it will have to be a trip to the stealers.
I had fun and games trying to find an O ring for the fork tops because both were leaking quite badly. Never did find them though and Yamaha don't sell them separately and a replacement fork top is £yike.
As it turns out, I didn't need them because the problem was corrosion in the fork top. I had my fork tops level with the yoke, so I presume salt water had sat there and and over time worked it's way in. I've got the fork tops just a couple of mm above the yoke to prevent it happening again and of course a bit of the ol' red rubber grease around the seal. Before you do anything, whip the tops off and see if there's any corrosion. Even the smallest spec of dry white aluminium oxide can cause the leak. Rubber + corrosion = zero seal.
26-07-14, 10:12 PM
Can't remember the size but you can buy O ring kits for not much money with several different sizes.
http://www.ebay.co.uk/itm/419pc-O-RING-O...2561a2dc1a I just nicked a few from my mate's kit as mine didn't have the right ones. |
« Next Oldest | Next Newest »
![[Image: 125377.png]](http://mefi.us/images/fuelly/smallsig-uk/125377.png)
