Advice on front &Rear caliphers
I posted last week that I had a problem with my right side ffront Caliper photo attached. I thought I would check out the left side and the rear as well. All fecking slack been riding a death trap. Not happy I had new front pads fitted in April that garage is going to get a rocket.
I am better at maintaining rather large marine engines than FZ1's I have attached several pic's of the rear caliper as well.
I assume there is only 1 securing bolt for the rear caliper?? In the pics I am pointing at 2 bolts , top one by the bleed nipple is the securing bolt for the caliper? yes? and the other one seems to have a rubber type boot/ Is that a balancing valve for the rear ABS??? and really no need to touch this?
The top one by the bleed nipple was backed off about 4 turns, am I correct to assume that this should should tight/ I have tightened it up hard. Again I have checked the caliper assume there should be a certain amount of float/movement if you grip it and twist back and forth.
Any advice apprecated. I am going to get the bike to a dealers and get the thing checked over, not a lot of confidence in the thing now. Not good to find out the brakes are falling off the fecking thing when two days ago I had her batting along flatout.
What is really pissing me off is I had this bike serviced and MOT'd by Marriotts of Birkenhead the day before I rode her all the way down to Spain. I will be dropping them an email, makes you laugh though this bike just passed the Spanish version of the MOT last week after I had fitted a new EU headlight. All MOT's would appear to be a waste of time.
<a href="http://s1087.photobucket.com/user/lew600fazer/media/DSC_0082.jpg.html" target="_blank"><img src="http://i1087.photobucket.com/albums/j478/lew600fazer/DSC_0082.jpg" border="0" alt="Right front calliper bolt missing photo DSC_0082.jpg"/></a> <a href="http://s1087.photobucket.com/user/lew600fazer/media/DSC_0083.jpg.html" target="_blank"><img src="http://i1087.photobucket.com/albums/j478/lew600fazer/DSC_0083.jpg" border="0" alt="rear calliper photo DSC_0083.jpg"/></a>
<a href="http://s1087.photobucket.com/user/lew600fazer/media/DSC_0084.jpg.html" target="_blank"><img src="http://i1087.photobucket.com/albums/j478/lew600fazer/DSC_0084.jpg" border="0" alt=" photo DSC_0084.jpg"/></a>
<a href="http://s1087.photobucket.com/user/lew600fazer/media/DSC_0086.jpg.html" target="_blank"><img src="http://i1087.photobucket.com/albums/j478/lew600fazer/DSC_0086.jpg" border="0" alt=" photo DSC_0086.jpg"/></a>
I am not quite sure what your complaint is. An MOT is not going to check that bolts are correctly torqued, only that the brakes do their job. You can try to give out to the dealers or MOT shops  if you like, but they are going to tell you the same thing that I am. It is your bike and your life. Take as much or as little care of each as you want.
Looking at the parts fiche (which I suggest you use since you don't appear to have the Haynes manual) the rear caliper is held on to the carrier with TWO bolts, not one. Check that you haven't lost another one.  http://www.yamahamotorcyclespares.co.uk/...iper?uID=0
Yeah, I agree with Paul above. It's your bike, your life, your responsibility. There's no point passing the blame onto others or bleating about what's happened,  accept it as a warning & in future take a more pro active role in the bike's maintenance. You don't need an engineering degree to check the tightness of nuts, bolts & fasteners.
The front caliper holding bolts should be torqued to 29ft/lbs & coated with blue loctite. The rear caliper bolts to 20ft/lb &16ft/lb & again coated with blue loctite.
Tightening them to "hard" isn't recognised as an acceptable measurement.
To reply to above posts I agree it is my responsibility to ensure the bike is maintained in a road worthy condition. But one would expect when it is serviced by an authourised Yamaha dealer it would have had the bolts set to the correct torque and not be backing off like this. Yes I will keep a better eye on things now that I am aware that they can become an issue. I have on order a complete set of caliper bolts and will add a touch of loctite blue when fitting. I may go one step further and drill the heads and pair wire them in as extra security.
Having been at sea for 43+years as a marine engineer and the last load of years sailing an office desk so to speak one has rather forgotten engineering basics. Now I have retired I am sure I will soon catch up.
Quote:To reply to above posts I agree it is my responsibility to ensure the bike is maintained in a road worthy condition. But one would expect when it is serviced by an authourised Yamaha dealer it would have had the bolts set to the correct torque and not be backing off like this. Yes I will keep a better eye on things now that I am aware that they can become an issue. I have on order a complete set of caliper bolts and will add a touch of loctite blue when fitting. I may go one step further and drill the heads and pair wire them in as extra security.
You are absolutely right Lew.  If you have paid a Yamaha dealer, and no doubt paid em a fortune to service and MOT your bike you should not have screws winding out and falling off your bike and certainly not brake screws.
However you will now be aware of how shoddy dealer work can be, and yes you are better off looking after basic maintenance yourself, you'll do it right.
By the way I wouldn't use loctite, I do the opposite I stick a tiny smear of copper ease as things get hot down there and I wanna know I'll be able to pop my calliper off again.  I do like to use torque wrenches, but then again copper ease can render torque settings pointless so I do the brake calliper mounts by hand.  As a former marine engineer (mechanic?) I'm sure basic bike maintenance will come back easy to you.  Get a maintenance manual, plus there's loads of tutorials all over the web.
Give the dealer hell, get em to put things right, but the in the future - just don't bother with them, do it yourself.
ps don't forget the red rubber grease (another thing dealers don't do)
[Image: 2270140426_f321dec1d4_z.jpg?zz=1]
It's amazing the difference it can make, stripping the calliper off the bike, using brake cleaner, carefully moving the pistons back and forth and lubing with the red rubber grease.
Oh and then making sure the bolts are tight :lol
(22-07-14, 07:25 PM)VNA link Wrote:
Quote:.... I may go one step further and drill the heads and pair wire them in as extra security....
...By the way I wouldn't use loctite, I do the opposite I stick a tiny smear of copper ease as things get hot down there and I wanna know I'll be able to pop my calliper off again...
I really, really would not recommend greasing up brake bolts. Apart from the obvious reason that you have already mentioned of screwing up the torque, or the fact that you are now throwing three different metals into contact in a hot and cold environment, begging the corrosion issues that entails, it doesn't make any sense because the important thing here is not that you can lossen them easily at a later time, it is that they do not lossen for any reason without deliberate effort! Nor would I suggest that weakening the bolts that hold your brakes on by drilling holes in them couild be considered a good idea either.
When you use clean, grease free bolts in clean, grease free mountings with a decent dab of loctite and tighten to the correct torque, then the loctite will do its job and prevent vibration and heat cycles from lossening the bolt, while also provideing an anerobic seal which prevents the ingress of air, water, salt and other oxidisers, so reduceing corrosion. And the fact that you have used the correct torque means the bolt will not be stretched or damaged which in turn means it will come lose when the appropriate lossening torque is applied.
The reason most people do it this way is because it is simple and it works.
Quote:The reason most people do it this way is because it is simple and it works.
Not so sure of that.
Also with extreme heat cycles, water, dirt, salt etc, well that's the reason for the copper ease.  Brake screws have a habit of seizing up.  And as they are usually screws not bolts, you don't want damage those threads (usually a steel screw into soft aluminium)
The only time I have experienced difficulty undoing brake bleed screws is where they have been over-tightened or serious corrosion(lack of preventative maintenance/regular proper cleaning) is present.
If,as PaulSmith says, you assemble clean calliper bolts into clean callipers using loctite & correct torque values,it is unnecessary to drill & lockwire said bolts.
I think the moral of this tale is that, yes in an ideal world, all bike mechanics/dealers workshops would check every fastener on bikes as part of service schedule.
However we know that this doesnt happen and the onus is on us as riders/owners to ensure our bikes are "fit for purpose".
If you look at garage bills closely the bulk of the cost is labour then add on parts at full retail value-look what they charge for say 3 litres of oil!- then to cap it all; VAT @ 20%!
Most of us on here are "enthusiastic" owners-many doing some or all of their own work on bikes/cages whatever.
Done properly it adds to the riding pleasure, knowing your bike is as good as it can be,leaving you free to concentrate on what the road brings.
Always amazes me how many right ways there are to a job on an internet forum :lol
Either you didn't read, or you didn't understand what I posted. If you actually know the difference between a bolt and a screw, then you should also know that being able to loosen the caliper easily is only a secondary objective. The primary purpose of the excercise is ensuring that it does not loosen unintentionally. When assembled as per recommended best practice, you will not have a  problem with them loosening unintentionally and you will not have a problem with siezing. Done your way, you increase the risks of seizing by encouraging corrosion by introducing copper, and you increase the risks of unintended loosening by introducing grease, so failing both objectives.
There is absolutely nothing wrong with drilling the head of a bolt and wiring the pair togather it is a well established and accepted engineering practice, It all depends on the size of the hole, so for instance a 1mm/1.5mm hole nothing wrong at all.
A torque wrench is only as good as the last time it was calibrated and that should be done annually, if one wants to split hairs.
The proper way and most effective method of tightening a bolt would be to apply a smear of Mollycoat G to the thread and the contact point were the bolt head contacts whatever is being torqued up that way you will achieve the correct setting.
Next time you are in a racing paddock have a look and see how many bikes do not have bolts drilled and wired, if it is good enough for the Dunlop boys will be good enough for me.
Okay explain the differance between a set bolt and a bolt
Quote:Always amazes me how many right ways there are to a job on an internet forum
Aye well, or it's amazing how complicated the simplest of tasks can become.
Lest deal with three things,
1. The Dealer
2.  The fastener and loctite
3.  Why you should use copper ease.
Oh yes Lew maybe
4 - torque wrenches.
Oh god!
1.  The Dealer
Which kinda partly covers two.  If the screw is tightened to the correct torque in this application then it will not come loose.  An annual service should include a brake inspection and clean.  The dealer will tell you to leave the servicing to them, that covers the brakes.  The dealer either did not torque the mounting screws or did not apply enough torque (see 4).  If you had your car serviced you might be a bit peeved if the brake callipers fell off - it's no different for a bike.  Lew should complain to his dealer and his dealer should, if they accept his complaint, make him happy (I mean really make him happy - they focced up big style).  Loose calliper mounts are unacceptable.
Quote:The primary purpose of the excercise is ensuring that it does not loosen unintentionally.
That is achieved by applying the correct torque to the mounting screw.  Perhaps if somebody has the official Yamaha they can tell us if Loctite (or similar) is recommended.  There is no mention of it in my clymer  manual.  Logically I don't think it would be.
Quote:When you use clean, grease free bolts in clean, grease free mountings with a decent dab of loctite and tighten to the correct torque, then the loctite will do its job and prevent vibration and heat cycles from lossening the bolt, while also provideing an anerobic seal which prevents the ingress of air, water, salt and other oxidisers, so reduceing corrosion. And the fact that you have used the correct torque means the bolt will not be stretched or damaged which in turn means it will come lose when the appropriate lossening torque is applied.
Indeed you need to prevent the ingress of water (we'll come to the reason for that in a moment) but to do so you need to cover the whole thread in loctite.  Now we have a screw that goes into a soft aluminium thread and a darn good bond along it's entire length.  There is now a danger (I think) that the loosening torque will considerably exceed the tightening torque and result in possible damage to the thread.  Not a problem with a nut and bolt arrangement, if they seize for whatever reason get em off and throw away.  Damage the thread on your calliper mount and you might want to cry.  Do correct me if I am wrong, perhaps with your source, but I don't think is best practise.
3.  Why you should use Copper Ease
Quote:Done your way, you increase the risks of seizing by encouraging corrosion by introducing copper, and you increase the risks of unintended loosening by introducing grease, so failing both objectives.
Cheeky foccer :lol
What I have done is introduced an anti-seize compound to protect the soft aluminium threads.  You are correct that the reason we have an issue here is due to two dissimilar metals.  You may well find that many maintenance manuals do not mention the use of an anti-seize compound.  The reason for this is, I suspect (and I'm taking a guess here), is that they are written in dry climates.
For the metals to react we need to introduce water to start the electrochemical process.  You then get erosion of the most chemically active metal, in our case it will be the aluminium, plus you begin to form a bond.  We need to protect that precious aluminium at all costs, we can't just throw it away like we could, if we wanted to, the screw.
So as we live in a wet climate (certainly I do in Ayrshire, umm though right now I think I'm stuck in the Bahamas!) we need a solution.
So we introduce our magical anti-seize compound.  It's copper carried in a grease.  The grease will exclude the water so hopefully we won't get any electrochemical reaction.  But just in case, and with all that heat and yup water, our grease will very probably get burnt off or washed away, so we have the copper. The copper is nice and soft so we'll be able to get the screw back out but also it's gonna act as a sacrificial metal.
When the water gets in, as the copper is now the most active metal in our mix, it's the copper that will be eroded and in doing so protects our soft aluminium thread.  Copper ease is perfect and recommended in our climate for use on brake calliper mounting screws.
4.  Torque wrenches and settings.
If you are worried about the torque setting when using copper ease, with a bit of googling you should be able to find correction tables for various anti-seize compounds.  You need to also check the manufactures figure to make sure grease or anti-seize compound has not already been recommended and already factored in.
In my personal opinion, if you are going to use  torque wrenches (not everybody will agree with this) then get good uns.  I like Britool, but Norbar, Facom, Bacho and the like are all good.
If you really wanna get it spot on buy a quality torque wrench analyser and get it calibrated every other year (needs to be mounted on a solid bench by the way).  Most of the torque wrenches we have at work have ranges marked on them but no scale.  They are set up, checked for repeatability, locked and a certificate issued.  They are then used and rechecked and part two of the certificate completed.
Me?  I've been copper easing they brake mounting screws and nipping em up by hand (more accurate than a cheap torque wrench?) for over 20 years and I've never ever had one come loose and nor have I ever had a problem getting em back off.
So I suggest Paul that you pop your callipers off, clean all the loctite off the mounting screws and apply a thin smear of copper ease on the threads and reassemble.
Phew.
Nothing useful to add, but glad after 48 years I finally know difference between a screw (a threaded fastener you measure torque from when tightening its head) and a bolt (a threaded fastener that you measure torque from when tightening a nut),  so thanks.
(24-07-14, 07:34 PM)PieEater link Wrote: Nothing useful to add, but glad after 48 years I finally know difference between a screw (a threaded fastener you measure torque from when tightening its head) and a bolt (a threaded fastener that you measure torque from when tightening a nut),  so thanks.
A Set Bolt has a full thread the length of it a Bolt has not.
Just toss this one into the mix, are there helicoils fitted to the Callipher securing bolt threads or are they tapped Alloy?
Would be quality if they had Helicoils fitted as standard.
(24-07-14, 03:51 PM)lew600fazer link Wrote: There is absolutely nothing wrong with drilling the head of a bolt ...
Of course not, if you do it right. However, you have not really shown any evidence that you are the sort of person likely to do it right. The mere fact that you are suggesting it as a possible solution to you not checking your own bike after someone else works on it re-inforces that opinion. I will be happy to apologise if I have mis-judged you, but I do suggest you take another stroll down pit lane to see which bolts are wired and which are not. In my experience, the bolts that would put others at risk if they failed (oil, coolent etc) are the ones that are wired. The ones that would just kill you are your own problem. I have certainly never seen brake bolts being wired as it would take far to long to change the pads.
(24-07-14, 06:36 PM)VNA link Wrote: Aye well, or it's amazing how complicated the simplest of tasks can become.
I could not agree more...
I actually agree with most of what you have written but the bit that worries me is...
but in your own words, "but then again copper ease can render torque settings pointless".
Your only real objection to using loctite seems to be that
Quote:"There is now a danger (I think) that the loosening torque will considerably exceed the tightening torque and result in possible damage to the thread".
If you read up on loctite you will see it is true that the loosening torque exceeds tighening torque, but not to the point where is a serious concern.  Certainly, in my opinion, it is far less of a concern then using guesstimated torque on greased up bolts holding safety equipement in place. There are exceptions of course, but they tend to concern tightening torques that deliberatly strain the bolts and so do not apply in normal motorbike DIY maintenance.
Finally, you asked if Yamaha recommeded the use of loctite on these bolts, which seemed like a reasonable question. And even though I knew that they would, I checked anyway so I could quote it to you and according to the service manual I have (2001 5LV1-AE1 section 4-16) , I am quite embarressed to have to admit that they do not. 40Nm but no mention of loctite.  I would have put money on it, but there we go. And no, they do not suggest copper grease!
Quote:Of course not, if you do it right. However, you have not really shown any evidence that you are the sort of person likely to do it right. The mere fact that you are suggesting it as a possible solution to you not checking your own bike after someone else works on it re-inforces that opinion. I will be happy to apologise if I have mis-judged you, but I do suggest you take another stroll down pit lane to see which bolts are wired and which are not. In my experience, the bolts that would put others at risk if they failed (oil, coolent etc) are the ones that are wired. The ones that would just kill you are your own problem. I have certainly never seen brake bolts being wired as it would take far to long to change the pads.
The last time I had a dealer service was 2005.  I took my thou in to get it serviced purely to keep my warranty valid.  The price then was 55 quid and hour plus VAT!  I hate to think what it is today.  Franchised dealers will tell you that they are the servicing experts, that and considering the rates that they charge means you should not have to check their work.  Nor do all riders own torque wrenches, know what the torque setting is, so forth and so on, which is why a lot of people pays others - the experts - to do the work.
The bottom line here is that the dealer failed to tighten the mounting screws correctly.  Or, hey who knows maybe Lew rides everywhere like he's in the TT, but I kinda doubt it.
I think what we might both agree on - is that the 'experts' ain't as smart as they'll tell you they are, and that too many dealers are just smart looking polished cowboy outfits (not saying there ain't some spot on dealers and workshops out there)  So yeah, it's a good idea to take an interest in your bike, learn simple basic maintenance like brake calliper cleaning, save some cash and know the job is done right.
Perhaps the race series that you participated in Paul did not require any brake lock wiring but many others do.  Some wiring is mandatory, some recommendation.  Google is your geek - so here's a prep guide to The Manx Grand Prix.
http://www.manxgrandprix.org/MGP-Info/Ma...reparation
Quote:but in your own words, "but then again copper ease can render torque settings pointless".
Read 4 again in my previous post.  Think carefully about your use and reliance on torque wrenches.  Again google is your geek - there are correction factors for using anti-seize compounds.  Note I say anti-seize compound not grease.
Quote:If you read up on loctite you will see it is true that the loosening torque exceeds tighening torque, but not to the point where is a serious concern.  Certainly, in my opinion, it is far less of a concern then using guesstimated torque on greased up bolts holding safety equipement in place. There are exceptions of course, but they tend to concern tightening torques that deliberatly strain the bolts and so do not apply in normal motorbike DIY maintenance.
You might wonder why racers have to lock-wire the calliper mounting screws when loctite arguably could do the same job.  Lets first accept that race bikes are used differently and subject to serious amounts of abuse when compared to any road bike.  We need belt and braces here.  So, there are probably two reasons why lock-wire is the preferred belt and braces method and not loctite.
1.  The application of loctite cannot be satisfactorily inspected by the race tech inspector.
2.  Using loctite on frequently dismantled parts (ie for regular maintenance) is not generally recommended, and less again so on aluminium threads.
I would take a guess that if racers were given the option of using loctite on callipers mounts (oh so quick and easy) and/or lock-wiring if required, they would all pick lock-wire and no loctite every time.
Quote:And no, they do not suggest copper grease!
It's not a grease, it's an anti-seize compound.  Steel onto steel the soft copper will allow you to loosen that thread.  Steel onto aluminium it will not only allow you to loosen the thread but also protect that soft aluminium thread by acting as a sacrificial metal.
Lew,
Don't go daft and lock-wire your calliper mounting screws, and for God's sake don't touch that loctite (you probably know that anyway) just stick a wee smear o copper ease on the threads and nip em up - job done.
(25-07-14, 02:58 PM)PaulSmith link Wrote: Of course not, if you do it right. However, you have not really shown any evidence that you are the sort of person likely to do it right.
Neither have you really, have you? Preaching about loctite-ing the bolts...
In a sense, fair play in that you've come back and admitted you were wrong, but if VNA hadn't argued with you, that wouldn't have happened, would it?
Be careful out there kids, don't believe what you read on the Internet, there's a lot of people out there don't know what they're talking about...
Quote:In a sense, fair play in that you've come back and admitted you were wrong, but if VNA hadn't argued with you, that wouldn't have happened, would it?
Not like me to argue with someone, eh? :lol
But seriously, Lew's had a problem, asked a question and he's been slagged off and fed a load of mince.
And Paul is still determined to use that loctite.
Quote:Be careful out there kids, don't believe what you read on the Internet, there's a lot of people out there don't know what they're talking about...
Aye, and everyday is a learning day.  We all foc stuff up now and again.  I have to say this is the first I'd heard of calliper mounting screws being loctited.
Google is your geek, and Paul's statement that it's best practise and what most folks do had me googling.  And indeed lots of folks are doing it, many claiming that's what the manufactuerer recommends and perhaps they do.  But googling also reveals a lot of folks asking how to fix their stripped calliper mount threads  :eek  And guess what they were using.
Another thing that's all over the internet is not to use copper ease as apparently it'll cause terrible corrosion when in fact with a steel screw and an aluminium thread it's a life saver, or rather a thread saver.
But hey that's the internet for you.
