18-07-14, 03:47 PM
Hiya all. A friend of mine is having a problem with his fazer and I was wondering if anyone could diagnose the issue from the evidence I have ?
Cheers
Issue: above 6,000 rpm loss of power engine sounds like it is misfiring/rough
Tried
: coils swapped with known good
: TPS swapped with known good
: plugs swapped with known good
: ignition unit swapped with known good
: breather tubes checked
: reg/rec swapped with known good
: all electrical cables checked for corrosion
Apparently the carbs have been balanced recently although I understood that normally affected low revs..
To all intents and purposes the electrical system seems fine. The brakes, lights, cooling system, clutch and gears work too.
Any ideas please ?
Cheers
Tried
Any ideas please ?
Opinions are like A**holes, Everyone has one. Some people seem to have more than one though which is a bit odd.
![[Image: 242673.png]](http://badges.fuelly.com/images/smallsig-uk/242673.png)
![[Image: 174802.png]](http://badges.fuelly.com/images/smallsig-uk/174802.png)
