12-07-14, 04:43 PM
Best place to find them I can't find them anywhere wemoto eBay etc or are they called something else.
Gen 1 ignition leads/ht lead
12-07-14, 04:43 PM
12-07-14, 05:28 PM
12-07-14, 05:36 PM
Bloody hell wonder if I can find some breaking one
12-07-14, 05:42 PM
does anyone know as your sat on the bike which number the far right coil is? 1-4 or 2-3.
12-07-14, 07:12 PM
What exactly is the problem???
As you sit on the bike 1 is on you left 4 on you right.
12-07-14, 08:46 PM
Number 4 has tore in half causing my dad to have a major lumpy ride home from glassen dock today
12-07-14, 08:54 PM
Could you use these? http://www.ebay.co.uk/itm/IGNITION-LEAD-...19e90d6026
It's the rubber but that has ripped in half not the lead great idea tho mate thanks.maybe I will have to buy the £40 eBay ones
12-07-14, 09:00 PM
12-07-14, 09:06 PM
The top part which goes over the spark plug has ripped managed to push back on a seemed to work ok for awhile but buy the time went 20miles or so bike was only running on 3 again. I think it's the rubber elbow bit not sure if it's all one piece or not and bike is at my dads so can't investigate further at the moment.there are a set for £40 on eBay and thinking it maybe the easiest replacement tbh
12-07-14, 10:24 PM
The plug cap is a separate part to the lead.
The cap screws on to the lead and they will come apart if pulled by the lead instead of the rubber on the plug cap. Cut 5mm off the lead and push it into the cap and then twist the cap clockwise while pushing the lead in. It will eventually tighten a bit then push the cap back on the plug. This picture is a full plug cap on its own. The rubbery part at the top is to seal against water ingress.
13-07-14, 01:36 AM
Unfazed that's exactly the bit I need I'll look up the part in the morning. Thanks that's great
13-07-14, 09:10 AM
£80 for 1 cool cap from wemoto/ajsutton I'm gonna go to hills Tuesday and get a used set I think
Check ebay or Fazerspares plenty secondhand ones around.
When looking check the 2001 R1 as it has the same plug caps. http://www.ebay.co.uk/itm/Yamaha-FZS1000...4d198c4268 http://www.fazerspares.com/catalogue/147...trical.htm
13-07-14, 09:29 PM
13-07-14, 10:21 PM
Hell's bells. I thought I had the most corroded Fazer cam box cover. I must try harder.
13-07-14, 11:18 PM
(13-07-14, 09:29 PM)solorider link Wrote: this is what I did to mine, got rid of the coils with leads as mine had corroded internally on the plug cap
GixerSix -
Z1000SX; FZS1000 Gen1; GSXR600WV SRAD; GPz550A4. TT Addict
14-07-14, 08:18 PM
(13-07-14, 11:18 PM)gixersix link Wrote: [quote author=solorider link=topic=13983.msg158367#msg158367 date=1405283395][/quote] The coils I have are off a Kawasaki and I have a set of honda CBR600 coils as well, the ohms are the same, as to wiring don't wire the logical way, the bike won't run, you have to wire in series, there is a few topics with wiring diagrams online, the yamaha coils have a boot to stop water getting into the plug holes big are not as common when buying a set of 4, and I don't know of the ohms are the same, you can also run suzuki coils as well. |
« Next Oldest | Next Newest »
