FS: FZS 600 chain guard, rear brake caliper and other bits
Having a bit of a clear out:-
One original chain guard off a 2003 FZS600. Good nick.
SOLD
One original rear brake caliper off 2003 FZS600. Seized, appears to need new seals. Bit scruffy, lost a little paint. Includes set of almost new pads.
£30
One original rear brake tension bar off 2003 FZS600. Has a little corrosion under paint, but would be fine after quick sand a spray with hammerright.
£5
One rear brake mount off a Gen 1 Fazer 1000. Good nick.
£10
Doubt postage will be much for these, certainly a fiver or less. Or can meetup around London/Essex area.
Hi
Is the rear brake caliper still available? Is so I'm interested as mine is beyond salvaging!
I'm not an expert mechanic, but presume it's the rear caliper unit as a whole?
Thanks
John
Yep brake caliper still available. Yes whole caliper unit with two almost new pads in place. It is currently seized, one piston moves a bit, one hardly at all. Can just see seals coming out. What I can see of the pistons looks alright though. Probably be ok with a strip down and new seals. Drop me a PM if you still fancy having a bash at it. Should be able to get 1st class postage for a fiver (£4 2nd class).
