Knocking front forks
Hi,  I recently removed the front forks so I could spray them which turned out really well, very please with them....but after I refitted them, the front end knocks when I go over bumps, large or small.
All the bolt are tight and I've tried altering the adjustment on top of the forks.
Any ideas what it could be?
Many Thanks
The forks could be bottoming out at either end of travel.  Possibly low on fork oil.
Thanks for the reply.
It doesn't look like it's bottoming out. It was ok before I removed the forks and I didn't see any oil leaking out.
Does having the forks upside down while spraying them effect them?
Is there something I could of upset by removing them?
Make sure the front wheel spins freely if the brake pads are not releasing in the calipers can cause a knocking noise.
Worth checking head bearings too. Might have loosened off a bit with forks going in and out
Thanks for the advice, I'll check tomorrow and let you know.
(19-06-14, 08:50 PM)scoobie_paws link Wrote: Worth checking head bearings too. Might have loosened off a bit with forks going in and out
The head bearing nut on top had somehow worked loose, few turns with a spanner and all is good again.
Thanks.
(20-06-14, 12:12 PM)emjaydee link Wrote: [quote author=scoobie_paws link=topic=13699.msg154745#msg154745 date=1403207439]
Thanks.
Woohoo I solved a problem for someone..... must treat myself to many beers  :lol
