15-06-14, 04:46 PM
		chain and sprockets been replaced on bike recently (before i got it) and the chain has major tight spot. don't think it saw any lube and was pretty bad on way home after i bought it. Was ok on test ride couple of days earlier but was wet so think it buggered it a bit more.
anyhoo spent couple of hours the other day working each link free with chain lube in each one, that was fun, and seemed to sort it and was running free. short run and was ok, readjusted the chain as moved a bit after lube. Job done i thought.
well ride out today and its back, almost no flex in chain at one area, roll in on and has 35-40mm as should. Should i redo it again or bite the bullet and get a new chain. was a did 530vm so not cheap shite. sprockets look as new so would prob keep them unless they are also part of the problem tho don't know how.
your thoughts are much appreciated
