Hi all been fettling the new girl and noticed that she is quite rattly on tick over until I pull clutch and then goes quiet.
Could this be cam chain tensioner? Thought that would continue clutch in or out but not sure
Is it normal or do I need to poke about in the clutch?
On plus side new conti road attack 2 tyres on today and feel nice but will run in tomorrow :-) also new ebc hh pads at front as old ones had about a mm left :-\ tried to replace sprocket but with 12 mm but looks like a two man job as just turns motor over with breaker bar.... Still least it means old one won't come off anytime soon
Cheers
Mark
It sounds like the clutch rattling it can often be improved by balancing the carbs.
mine's doing that too...... time to upset the neighbours by balancing my carbs...... unless anyone else has any other ideas....
I just joined the forum to search for the same problem. Mine sounds like a road whacker on tickover in neutral but the noise goes away when the clutch is pulled in. I've read posts on other sites saying this is "normal", is it really? :rolleyes
They all rumble like that sir. :lol
Typical of multiplate wet clutch in line fours, balancing the carbs helps, but never completely gets rid of it.
You should listen to an old SOHC 750-4 Honda
you could also try adjusting the clutch cable a little to take some of the slack. May reduce it a little, no harm in trying.
including ones who like chocolate....
18-06-14, 08:19 AM
(This post was last modified: 18-06-14, 08:24 AM by mick0905.)
I need to hear another one. I seriously thought I'd bought a pup til I read it was "normal". What I don't know yet is how normal is normal.
The bike rides fine and selects all gears smoothly but I get the feeling when I'm stopped at traffic lights that everyone is looking round to see where the racket is coming from.
I'll see if I can upload a video of mine running to Youtube so you can compare it to yours scoobie.
That is most certainly not your normal Fazer clutch rumble and they definitely do not all sound anything like that. :eek
Buy a clutch cover gasket, put the bike on the side stand (saves having to drain the oil) and take off the clutch cover and have a good look at the clutch, Sounds like something broken or badly worn.
If necessary take out the plates and check everything inside there. You could have a loose of broken clutch bolt.
If the clutch was changed there is a good chance the clutch bolts were over tighten and one was stripped.
