I'm confused, I've had the sprocket cover off to replace the sprocket nut as it had come loose. I've put it back together after a week of not using it and it cranks but will not start. After playing around with it over and over eventually it started, I thought that would be it but same again this morning and when I got to work I turned it off switched straight back on and again same, it wouldn't start. I'm hoping it'll start when I finish later!
The only things I've done to get it started are playing with the sidestand, cranking over and over and pulling in the clutch but there isn't one of those things that solves the problem it just seems to go eventually. I'm was thinking maybe it's the sidestand switch but would it not crank if thats the case? Anyway I can bypass or test this?
