Foxeye Mirror's
Has anybody taken these apart ? i am in the process of getting some bits powder coated, thought i get the mirrors painted as they are a bit tatty.
How do you remove the ball joint ?
it's a good life when your wife encourages you to go out and ride at the weekend,
in wife speak ( get out of the house )
There is a spring and a nut on the end of the stem but inside the casing. It holds and maintains tension with the stem and the casing.  To get at that nut you would have to remove the glass mirror part, and I don't know if that is possible without breaking it.
The other way would be to cut a hole in the bottom of the casing which is big enough to get in with a spanner. I have done this on a mirror that was slack to tighten up that nut, but I don't think you will want to go down that route. Maybe time for a can of spray paint instead.
Hi Limax, i agree  a can of spray paint, not worth the risk of breaking the glass.
Thanks  Smile
