fazer fzs 600
anyone help me out looking for a front fork top nut for a fazer fzs 600 1998 or tell me were to get one it is just the standard forks on the bike
http://www.ebay.co.uk/itm/YAMAHA-FZS-600...1c38358ef9
thanks for the reply doddsie but that id the top yoke nut i need the top nut for the fork
I take it you mean the screw-down top fork caps, and the 1998-99 versions have no preload adjusters in them?
Think I have a pair somewhere in the garage
What happened to your original(s)?
thats what i mean the ones on my forks are rounded so was looking for new ones as i have to do the seals if you have them how much you want mind the postage too can you take a pic and send it to i am kind of in a hurry for them
for kebab
As I thought, found a couple of sets in the garage
The Left-Hand-Side set are a bit stained / corroded, tho the hex pattern caps arent damaged / chewed up  - £15 inc P&P
The Right-Hand-Side set are cosmetically better, £20 inc P&P
[Image: Forkcaps_zps5fbe582a.jpg]
(31-05-14, 04:49 PM)h7thl link Wrote: thats what i mean the ones on my forks are rounded so was looking for new ones as i have to do the seals if you have them how much you want mind the postage too can you take a pic and send it to i am kind of in a hurry for them
for kebab
Usual reason for rounding is not loosing off the top yolk bolt before trying to loosen the Fork cap and tighten the fork cap before tightening the yolk bolt. Cap only need 23Nm torque
