Flasher
Today I had small problem
Rh flasher decided to stop and the arrow on rh side also stopped
Lh flasher worke fine and the arrow works
If I put hazards on on lh side work and lh arose
What problem?
Listen to flasher relay don't here it clicking even with lh side working?
If you've altered nothing lately, it'll be the switch contacts. Try spraying contact cleaner in there or better still remove, clean the contacts & reassemble. The flasher relay has 1 common feed so if 1 side works it can't be that
