rotating switches
Can anyone suggest how to stop both left and right switches rotating/moving as the plastic locater has been cut off/snapped..the screws are tight. I think a previous owner may have had different bars on...
Take the switch unit off, and a couple of layers of tape round the bar should do it. I've had best results from self amalgamating tape, and zinc oxide tape.
It's a bit trial and error to get the exact amount on there, bit worth it in the end, dome it on pretty much every bike I've owned.
[Image: 850481.png]
Thanks I'll give it a go
The tapes worked a treat thankyou. No more switches rotating.
Mint! Glad it's worked for ya 8)
[Image: 850481.png]
I see you've already fixed but in the past I've used the double sided foam tape you can get from the pound shop!
Some say...
(27-04-14, 09:15 PM)Punkstig link Wrote: I see you've already fixed but in the past I've used the double sided foam tape you can get from the pound shop!
How much does that cost
Haha
Some say...
