I'm in the habit of clutchless gearchanges (in both directions)
However, I don't know if this is ok or not, or if it's particularly bad for a FZS600 (May 2003 model)
Could you give your opinion? Especially those who know the anatomy of the FZS600's drive train.
Clutchless downshifts not for me...
Better to have it and not need it, than to need it and not have it..
As far as I'm aware, up is ok, down is not ok.
Manufacturers fit a clutch for a reason mate. You don't use your engine to brake as well do you? Both bad, and potentially expensive, habits.
Up is fine it is a crash box afterall
Its just a ride
(20-04-14, 08:43 PM)adeejaysdelight link Wrote:Manufacturers fit a clutch for a reason mate. You don't use your engine to brake as well do you? Both bad, and potentially expensive, habits.
Whats wrong with engine braking?
Do both on occasion, have had lots of people say that down the box clutchless will damage it, but I don't think it stands up as the forces going through the cogs are far less when slowing down than when accelerating; it's just a wee bit more of a knack to get it smooth
Manufacturers do indeed fit clutches for a reason.. Pullin away from standstill tends to get messy without it :lol
1st to 2nd use the clutch, after that all clutchless going up the gears. Always clutch it going down the box though.
That's my style, everyone's different and haven't lost a box yet in xx yrs and xx bikes.
Crack on riding it your own way fella, if you lose a box then you may change your style........assuming that was the cause of the box failing - if it ever does.[size=78%] [/size]
(20-04-14, 09:58 PM)His Dudeness link Wrote:[quote author=adeejaysdelight link=topic=12696.msg143055#msg143055 date=1398023019]
Brake pads are much cheaper than engines.
It causes unnecessary engine wear.
And your brake lights don't come on to warn following traffic that you are slowing up or stopping...
But what would I know.
(20-04-14, 11:05 PM)adeejaysdelight link Wrote:[quote author=His Dudeness link=topic=12696.msg143095#msg143095 date=1398027500]
What wear does it cause?
I always use engine braking, but not clutchless downshifts, that be daft!
Some say...
In answer to the op. I occasionally shift up the box clutchless...never down for me. I tend to use the clutch when just flitting about though.
I engine brake as well. In my view it actually causes more even wear on the box, never had any issues arise from it personally.
I use both engine braking and actual brakes to slow down.
In answer to those who say engines (& gear boxes) are more expensive to replace than brakes - only if using engine braking actually causes your engine/gearbox to break.
In nearly 40 years of riding, I've never had an engine break on me - despite clocking up over 50k miles on many of them - and using engine braking every time I ride.
Personally, I've spent far more on replacing brake pads and discs than I have on replacing/repairing worn out engines or gearboxes.
Not sure why engine braking causes wear? Those folks with big twins must wear their motors really fast, huh? :think
21-04-14, 12:04 AM
(This post was last modified: 21-04-14, 12:05 AM by Hiswitsend.)
+1 for the confusion over the extra wear, are people who don't use engine braking pulling the clutch in and coasting on the brakes until they accelerate again?
If you are braking with the drive still engaged and are braking faster than engine braking alone, then there are more forces acting on the drive train from the rear wheel increasing the rate at which the engine is being decelerated over and above the natural engine braking from being off throttle, no?
Or maybe it's just late :z
If you're giving it a big handful of revs to change down a couple of gears to get more engine braking, rather than just slowing naturally in whatever gear you're in, then you're wasting motion lotion and would be better off using the brakes, but still can't see much wear occuring (well maybe if you're changing down to the extent you're redlining the motor, but nobody is that mechanically unsympathetic, are they?)
Jeez, what am I saying, they'll be out there.... :eek
21-04-14, 12:14 AM
(This post was last modified: 21-04-14, 12:18 AM by Millietant.)
(20-04-14, 11:55 PM)richfzs link Wrote:Not sure why engine braking causes wear? Those folks with big twins must wear their motors really fast, huh? :think
I ride a big twin (Aprilia RSV) and use engine braking an awful lot, especially on track - no worn motor in 11 years and over 30k miles !
My wife doesn't like following me on this as much as when I'm on my FJ 1200 - only because I don't use the brakes as much, so she has to pick he own braking points
At worst it'll increase clutch plate wear a bit but couldn't it be by much. If you were going down that line of thinking you wouldn't go above 20mph because you're increasing wear on everything or you wouldn't go above 3000 RPM because you're wearing out the engine faster. It's not going to cause any appreciable wear imo. It's just part of riding a bike. If you're not doing it you're losing out on a lot of stopping power. Plus doing it means you're in the right gear at the right RPM ready to go when you come off the brakes.
engine braking to my knowledge was the thing to do untill pads and shoes became chaeper. now proper braking technique uses a mixture of engine and brakes, control of vehicle can be lost if taking engine out of drive. As for engine damage you'd be talking driving high speed dropping from 5th straight in to 1st or 2nd not just riding in a lower gear than needed and releasing throttle to slow down
including ones who like chocolate....
