idle flicker
hi folks . when my bike is warm and idleing at 1150 ther is aslight flickering of needle ,ino the bike needs service as it has only done 110 miles from last mot is this normal or what could be causingit bike rides fine thanke ct62
1150 is too low, sounds like it's hunting a bit.
Raise it  to 1250 or 1300 and see if it improves it.
thankyou will give this a go its my new bike will get manual. just joined its great love all the info
(07-04-14, 09:41 PM)darrsi link Wrote: 1150 is too low, sounds like it's hunting a bit.
There's an online manual on here you can download, not as good as a paper copy though.  Wink
cheers iv came across a cd version but im a dont fix it if it isnt broke guy its the good old fashioned manual for me
(07-04-14, 10:54 PM)darrsi link Wrote: There's an online manual on here you can download, not as good as a paper copy though.  Wink
Soon be time to balance the carbs!
Some say...
Never had my carbs right. Above 2thou it's as sweet as a nut, but around or below, it misses and chugs, like a lazy plug or something. Damned annoying when trickling in traffic. It chocks like a tractor, and pulling away smooths it out. Does the same thing parked and in neutral. I've vacced them. Shop has vacced them. Had them balanced. Waste of money - exactly the same.(Unless they did sod-all and just charged me for the privilege! wouldn't be surprised) Anyway - mine has the needle wavering up and down when at tickover. I've had it wavering now for 2 and a bit years. I am resigned to just saying "oh sod it !" - and putting up with it.
It never gets better, or worse, and has no apparent ill affect on the bike. Just get above it on the rev counter when in traffic.
The Reaper Returns !
(09-04-14, 10:16 PM)Gazbo link Wrote: Never had my carbs right. Above 2thou it's as sweet as a nut, but around or below, it misses and chugs, like a lazy plug or something. Damned annoying when trickling in traffic. It chocks like a tractor, and pulling away smooths it out. Does the same thing parked and in neutral. I've vacced them. Shop has vacced them. Had them balanced. Waste of money - exactly the same.(Unless they did sod-all and just charged me for the privilege! wouldn't be surprised) Anyway - mine has the needle wavering up and down when at tickover. I've had it wavering now for 2 and a bit years. I am resigned to just saying "oh sod it !" - and putting up with it.
Is there anyone you know who could lend you a Carb Tune kit?
I had my carbs balanced in a shop, then bought a kit and tried it myself and they were well out.
Or even buying a kit then using it once pays for itself compared to mechanics fees around my way, but then you get to use it again whenever!
When they're bang on it makes a big difference.
thanks for info .will see about carb ballance seen it done will give it a go myself  i read on forum it can quieten clutch rattle  will look at prices of carb tunner
(10-04-14, 06:54 AM)darrsi link Wrote: [quote author=Gazbo link=topic=12505.msg140626#msg140626 date=1397078175]
bnjjmmm,
