Hi,
Searched through the threads but I can't get a definite answer.
Does a FZS1000 caliper hanger fit on a FZS600?
Thanks
no
![[Image: 208008.png]](http://badges.fuelly.com/images/smallsig-uk/208008.png)
No worries
To be less blunt, I believe the internal diameter of the spidle is larger on the 1000 so would be loose on the 600. The overall hanger might be too thick too which would mean it wouldn't fit between the wheel and swing arm.
The 600 hanger is easy to mod so the 1000 calliper fits though. You know how to do it?
Chris
Since i bare a small amount of responsibility here i trawled through & can see a quote from fizzy
Quote
The FZS1000 and XJR1300 (blue spot 2002+) are the same part. I think in '06 or '07 the xjr1300 was upgraded to a silver spot and is supposidly better still.
+1 to what FF says. The mounting holes are the correct pitch, the only mod required to is the 600 caliper bracket, theres some metal in the way, not much, just enough to make the 2nd hole not line up untill its filed back, two minute job i did mine on the breakfast bar with a g clamp and half round file, shhhh dont tell SWIMBO Unquote
Thats what i was on about by saying you needed a file...i hadnt realised it was on the 600 mount but obviously you have one of them already.
Did it arrive then Emjay???
(03-04-14, 07:20 PM)noggythenog link Wrote: Did it arrive then Emjay???
Yes and no.....had it going to my in-laws but they weren't in to sign for it, i'll have to pick it up from the post office depot tomorrow.
Thanks for getting it to me so quickly.
had my FZS1000 rear caliper fitted today onto the 600 hanger,as stated above,you put the far end bolt through the caliper and into the 600's hanger and then try to line the other hole up,you will see just how little of the 600's hanger that you will need to grind down,mine was ground down still on the bike.you will have to take a smidgen off the far bolt hole end of the hanger as well
seemed very easy watching someone else do it!! :lol
good luck
04-04-14, 09:12 PM
(This post was last modified: 04-04-14, 09:21 PM by emjaydee.)
Pick up the caliper up from the depot today and I couldn't wait to fit on the bike.
First I removed the FZS1000 caliper bracket
Then I inserted left side bolt and offered it up into position to see where it needed grinding. I found that 2 points of the bracket needed grinding.
Using a Dremel, I ground down about 1-2mm from here........
![[Image: 04_zps1505b7b0.jpg]](http://i65.photobucket.com/albums/h239/emjaydee73/04_zps1505b7b0.jpg)
and here.....
then I fitted the torque arm off a Thunderace, which conveniently also arrived today. Took me around 30 from start to finish (fitting the torque arm took longer that the caliper).
Looks spot on mate and good pics to show how to mod the 600 calliper too.
Chris
So is the 2002+ xjr1300 blue spot the same as the fzs 1000? the look slightly different.......................
I have a 2007 XJR1300 rear caliper on mine (well, technically a silver spot version) and you mod the FZS caliper mounting bracket the same way as you would for the FZS 1000 caliper.
So I guess it's the same.
Pics to follow....some day
26-08-14, 12:43 AM
(This post was last modified: 26-08-14, 12:44 AM by MC680x0.)
Looks good mate, nice 1
Three lefts make a right
Which year 1000 caliper do I need for this mod?
(03-09-14, 11:27 AM)Pal link Wrote: Which year 1000 caliper do I need for this mod? :fish read the thread above (inc. noggy's post) and search
(03-09-14, 09:22 PM)tweetytek link Wrote: [quote author=Pal link=topic=12420.msg164793#msg164793 date=1409740060]
Yep, did that, it says that the XJR caliper is from 2002 on but nowhere does it mention what year fazer thou caliper to use.
And please stop hitting me with that fish, you're giving me a headache
Is like to whack it harder.!
It's says the fzs1000 , AND ,#AND#, the xjr ARE THE SAME PART and that the xjr part was upgraded in 06/07 , so by elimination your looking for a model 2002 .. 2005/6 are u not?
FZS1000 '01-'05
Yep, that would do nicely.
(04-09-14, 01:41 PM)tweetytek link Wrote: Is like to whack it harder.!
It's says the fzs1000 , AND ,#AND#, the xjr ARE THE SAME PART and that the xjr part was upgraded in 06/07 , so by elimination your looking for a model 2002 .. 2005/6 are u not? Nice edit
