Just in the middle of converting my standard front end to the r1 (early type) and have noticed a 10 thou run out on the fazer steering stem. Any opinions on whether is an acceptable tolerance will be greatly welcomed. Thanks in advance.
Good luck with the conversion. Pic when done hopefully?
Ten thou from where to where?
How did you measure it?
Cheers Sirg, will definitely post some pics mate. So far the conversion is going well, I am building a complete R1 front end first and then just do a complete one for another swap if that makes sense?
As for the run out screwdriver, it is measured by holding one end in a lathe and turning it whilst measuring with a dial gauge.
