New chain time - bigger sprocket on the FRONT?
It's time for a new chain - the cheapo one I stuck on the old sprockets 3 years ago is approaching end of life.
So, I'm toying with the idea of putting a larger sprocket on the front.  :eek
I'm not interested in pulling wheelies or riding like a dick, I more interested in MPG's on the way too and from work so the loss of accelleration isn't a problem.
Anyone tried anything like this before? How much difference will it make to the ride/MPG etc?
Would there be any clearance problems inside the cover? I'm thinking a smaller rear sprocket would have the same effect.
AFAIK you can get away with one or two more teeth on the front.
On tooth on the front is the equivelent of about 3 on the back - hence why I was thinking of doing that rather than changing the rear.
Ahh gotcha! I'm thinking about doing the same as I do a lot of motorway miles. Sounds like the front is the way to go.  Smile
Have a look at http://www.gearingcommander.com/ you can play about with the ratios and see what the effect on the speed, rpm at speed the change will have
Dave
thats handy - there was one on the old fazer site.
Gonna go for front +1 and rear -1
See how that goes, it it's too much I'll swap one for a standard.
If I put the back on the front and front on the back I can do 500MPH in 4th  :rollin
I went 1 down on the front and 1 up on the rear. It makes quite a difference. My riding style is obviously the polar opposite of yours, as I love to ping it about and care not for MPG and motorways. If I have to use the motorway, I'll take the SAAB. But my point is, one tooth at the front either way will make a noticeable difference. If that is done with a change at the rear, it will make a significant difference.
I tried one tooth up on the front, it was very noticeable, sluggish, forever changing down gear to overtake,  fuel comsumption INCREASED, I stuck with it for about 3k miles and then put the CORRECT sprocket back on,    Aaahhh  Lovely
Old enough to know better
Come to think of it, I've still got the bigger sprocket which you are very welcome to. It's only done 3k, try it on your old chain before you go out and spend money. PM me your address and I will pop it in the post, Fraser
(01-03-14, 01:34 PM)Fraser link Wrote: Come to think of it, I've still got the bigger sprocket which you are very welcome to. It's only done 3k, try it on your old chain before you go out and spend money. PM me your address and I will pop it in the post, Fraser
Good egg!
There be a good egg! 8)
what a luverly site this is!
That Gearing Commander site is a tad innacurrate: On stock gearing, it claims a 600 will do 230mph in 6th at the redline. I suspect it isn't taking power into consideration here (or rolling drag, or friction, or aerodynamics....  :lol :lol ), as a bike can only go as fast as its engine permits.
The Deef's apprentice
That's not a basis of Gearing Commander being inaccurate. The 600 would do 230mph in 6th at the redline... if it had the power to do so
The purpose is to show the gearing ratios and related speeds, not to debate the finer points of whether these speeds are possible or in what time they would be achieved
True, but then the bike has to have the power to accelerate with the added load upon it.
(01-03-14, 08:16 PM)Dead Eye link Wrote: That's not a basis of Gearing Commander being inaccurate. The 600 would do 230mph in 6th at the redline... if it had the power to do so
I've relatively certain I had mine quite close to the red line about 11k ish) , at about an indicated 150?
(01-03-14, 09:36 PM)JoeRock link Wrote: [quote author=Dead Eye link=topic=11868.msg130873#msg130873 date=1393701378]
I would imagine variations in the rolling diameter of the wheels and tyres will be the major factor there?
Apologies, you are correct and gearing commander puts 11,500 RPM in 6th as 143 MPH - Christo's data was wrong, which I didn't verify on the actual site. The dozy muppet was reading KPH not MPH Tongue
well i got the chain and sprockets today, +1 front , -1 rear so will fit them sometime in the next few months (wanna eek out the best I can from the current chain) although I don't think the current one will last long now - time between large adjustments (1/2 turn) is down to 3 weeks.
When I start using them I'll post back and let you all know the results. My mpg is consistent at 50 (+- 2) mpg so will see how the fuel consumption is affected.
(01-03-14, 10:18 PM)Dead Eye link Wrote: The dozy muppet
Not the first time that's been said  :rollin :rollin
(02-03-14, 03:52 AM)richfzs link Wrote: [quote author=Dead Eye link=topic=11868.msg130920#msg130920 date=1393708722]
The dozy muppet
I've been known to do it myself on occasion! :lol
