Main beam flash switch and carb rubbers
Just picked up my new Fazer and noticed that the "flash" switch, for the main beam doesn't work.  Is it easy to replace or do I need that whole unit on the handle bars that  it connects into?
Also, carb rubbers are in a right state, easy to replace or a garage job?  I'm no mechanic, I will happily change oil, balance carbs (badly LOL) adjust chain, I've done the rear pads once but it took ages.
Cheers
If you need carb rubbers I should have a good used set here in a couple of days..
Better to have it and not need it, than to need it and not have it..
ooooooo, yes please.  Are you replacing your ones?
I have messaged you re: the inlet rubbers.. cheers john
any ideas anyone?  Smile
Thanks!  :b  Shall I just spray it everywhere?  :\
BINGO!  good old WD40!  Smile  thanks for the advice.
One thing I've noticed about the bike after testing the main beam, I HAVE TWO HEADLIGHTS!!!!!  whooop whooop!  Looks like it's had the headlight mod done!  Smile
