bellypan Fitting
I've managed to aquire a used official Yamaha Gen2 Belly pan.  Smile
However, there are no bolts with it & the guy who I bought it from said it utilises the 4 bolts on the bottom of the engine.(sump?)
Is this right or is there an official fitting kit & if so any ideas where I get it from?
Thanks for any help.
Paradox - A bit like paracetamol but different.
I had just written a load of text about the fitment of a Gen 1 bellypan and then realised you wanted info about a Gen 2. Doh
Sorry I'm not sure but someone will be along in a minute to point you in the right direction.
If IRC there is a little bracket each side toward the rear of the belly pan as well as the straight through fixings.
Mine was fitted but I had a look yesterday and its 2 brackets ... ill take a pic tomorrow for you.
(15-02-14, 07:36 PM)Gary link Wrote: Mine was fitted but I had a look yesterday and its 2 brackets ... ill take a pic tomorrow for you.
Many thanks Gary Smile
(14-02-14, 04:38 PM)locksmith link Wrote: If IRC there is a little bracket each side toward the rear of the belly pan as well as the straight through fixings.
As I woke up an idiot - what does IRC mean?  :o
(14-02-14, 09:34 AM)Lez72 link Wrote: I had just written a load of text about the fitment of a Gen 1 bellypan and then realised you wanted info about a Gen 2. Doh
Been there. Done that! Wink
If I recall correctly it means iirc or something like that. Lol
(16-02-14, 10:51 PM)Andy FZS link Wrote: If I recall correctly it means iirc or something like that. Lol
:lol
I had a look in the garage yesterday as I have a damaged belly pan taken off the bike I wrote off.
No fittings I'm afraid, my lad took all the bits off the bike as I was laid up and couldn't walk, he obviously left the brackets on the bike.
Found out that I'm a twat as I had the necessary fitting brackets all along - it's just that they were already fixed inside the belly pan.  :o
The only reason that I know this is because I searched the interweb & found that someone on sportbikes.net had posted a fitting with pictures. (I would have shared the link but they are tricky & won't let me copy/paste the link)
Thanks everyone for your replies. :thumbup
Just bought some R&G bar end protectors.
Anyone know where they go? :b
