Crash bars
Right, who's got what and what do you see as the negative points of them?
I've got crash bungs atm but know from several previous experiences these are only good for dropping the bike at a standstill (which I've also done several times!)
I've narrowed my choice down to either Heed or Renntec, the full engine crash bars, not the smaller ones!
Some say...
I've got the full renntec ones on. Apart from being heavy, bulky and (some would say) ugly, theres no real negatives to them. I've yet to test mine out yet though thankfully.
I have the smaller ones with the three mounting points - these:
http://www.wemoto.com/bikes/Yamaha/FZS_6...s_-_Black/
I've dropped the bike once at a stand still since I've had these fitted (2 or 3 years, quite an acheivement for shortarsed me) and they did a considerably better job than the crash bungs fitted previously which allowed the edges of the front fairing to hit the deck and get foc'ed up. Like you, I think crash bungs on the 600 are not very effective, I think their position low down makes them less than ideal.
Renntec & Heed (latter look neater to me) look beefier but the above has done everything I'd expect from crash bars so the fact they're smaller, lighter & cheaper is a positive point in my book.
We id all this here http://foc-u.co.uk/index.php/topic,1655....l#msg95874
Im not sure about the webmoto being 3 pionts as the top one is on a long bar attached to a point much lower
Sorry just read that you are on about the larger ones
Yes, you're right they are in reality only attached to the frame at 2 points (I was just trying to differentiate from the ones in the 1st photo in your link)
What I did notice was that - whether intentionally designed to do so or not - because they are bolted to those plates, the bars can move a small amount, so there is a bit of "give" and the force is not directly transferred to the frame or engine bolts, not straight away at least. Another bonus is that it is very easy to remove the bars as you can simply remove them from the plates so you can leave the engine bolts in situ.
Quote:What I did notice was that - whether intentionally designed to do so or not - because they are bolted to those plates, the bars can move a small amount, so there is a bit of "give" and the force is not directly transferred to the frame
In that respect they are good
As well as protection my plan is to rivet sheet ally creating a belly pan, this is the main reason I'm looking at the bigger bars.
I'll have to eye things up cause in my mind I still can't decide whether to rivet over the top of the bars hiding them or under the bars to look a bit different!
Some say...
Oh I see, is the ally for cosmetic purposes only or will it do something more - keep the bike cleaner?
The bigger and beefier the bars, the better! Had a set on my tiger 1050. When it went down the engine and frame were untouched, the crash bars were mangled!
Worth every penny.
[Image: 850481.png]
heres mine for reference (I think they are renntec at least? came on the bike anyway!)
[Image: IMAG1567_zps0385dd84.jpg]
Mick - I know the renntec's have a hole for where the bung in the frame is, are they bolted through that part of the frame too? (below the seat, not the front of the bike!)
Some say...
Looking closer at the pic I'm assuming they're bolted in with the footpegs, is that right?
Some say...
aye, one of the bolts is into the footpeg/hanger Smile
Just one?
Some say...
The thing is the renntec's are more expensive than the Heed but if they bolt into the frame there that makes them a lot stronger!
Some say...
(26-01-14, 07:43 PM)Fuzzy link Wrote: Oh I see, is the ally for cosmetic purposes only or will it do something more - keep the bike cleaner?
Both, bearing in mind it'll probably be covered with tiger print!
Some say...
(26-01-14, 09:53 PM)Punkstig link Wrote: Just one?
just gone out and looked. there are two at the rear (both the top and bottom mounts for the footpeg hanger).
also one bolt at the front top into the frame, and one at the bottom front as well Smile
I have the genuine Yamaha ones, 5DM-W0741-00
It has been down the road 3 times and the saved a lot of damage to the engine casings. On my 3rd set. Had black, then chrome and now back to black again
http://kleinanzeigen.ebay.de/anzeigen/s-...3-222-4719
Yeah, I don't like them unfazed,  no supporting arm so mot as beefy as the Heed or Renntec!
Some say...
(27-01-14, 09:19 AM)Punkstig link Wrote: Yeah, I don't like them unfazed,  no supporting arm so mot as beefy as the Heed or Renntec!
I thought the same before my first off. I bought them originally for looks and fall over protection.
Was plesently surprised when they took the brunt in a the slide without anything other than road rash.
