Which plug heat range
Happy new year to you all Smile Santa got me a simmi race can for xmas and iv'e got a k and n filter to go with it. Im going to fit some new plugs next service and just wondered whether to fit cr 8 or 9 plugs with the new set up. I'm presuming this will lean off the mixture slightly and maybe run a bit warmer ? Im guessing either would be fine but wondered what more experienced Fazer owners would go for. Cheers  Smile
cr8 is standard
Spend a couple more quid on each and buy Iridium.  Wink
http://item.mobileweb.ebay.co.uk/viewite...495wt_1199
Go Iridium!
Mines been in 16000 miles and still look perfect!
Hi All. First and fore most happy New Year to one and all, Will have my fazer four years in the middle of January 10, Fitted the iridium plugs shortly after buying the bike at 46500 miles. Its now got 61500 miles on it didn’t touch the plugs since then. When are often are there changed.
20k
ok thanks. is there any need to remove and check, or just leave well enough alone.
Bought mine with 12k on it and now up to 34k- not touched the plugs!
Some say...
Thanks i will leave well enough alone.
Hey folks..
Can anyone tell me what is the difference (if any) between NGK Iridium  CR8EIX  and CR9EIX plugs, as both
types are listed on fleabay as suitable for a 2001 model FZS 600
http://www.ebay.co.uk/itm/NGK-Iridium-Mo...4857bcbdbf
http://www.ebay.ie/itm/NGK-Iridium-Spark...232a2d73ca
Cheers..
(13-01-14, 01:08 AM)Techs link Wrote: Hey folks..
Cheers..
8's are for a lower temperature range (i mean as in the weather) - they're the ones recommended for our temperature here in the UK for the FZS
Cheers Joe..
Seen as i'm only across the pond in Ireland i guess i should stick with the 8's then.
Smile
(13-01-14, 01:11 AM)JoeRock link Wrote: 8's are for a lower temperature range (i mean as in the weather) - they're the ones recommended for our temperature here in the UK for the FZS
http://www.ngksparkplugs.com/techinfo/sp...berkey.pdf
