New fazer owner!
Hey folks just got myself my first 'big' bike which is a 2001 fazer 600... and thinking it may be restricted because a fellow biker rode it back for me after buying and he said it felt a bit. .. lacking of power as it reached the 6000rpm mark.... is it easy enough to wip the tank off and get to the carb rubbers to check for blades/washers etc... A Haynes manual is on its way to me hence why I am asking haha
Hey ben, welcome mate
The 600 is all about high revs so if it is flat then could well be restricted
A few members have or have had theirs restricted so should be able to help you out.
Hope you enjoy the bike, does it run well apart from that?...if it doesnt then maybe something else is at fault.
Something else to check when you get time, whip the front sprocket cover off & check the sprocket nut, theres a known flaw, go to the search bar in here & type front sprocket nut & you can read all about it.
Nice one ill check the front sprocket as well then!
Cheers Smile
