no heating....
woke up this morning and no heating...hot water ok though...traced the fault to a blown "central heating control" in the airing cupboard....looks a bit burnt and iam surprised we did`nt hear it go.....its a drayton tempus seven about 18 years old,looking at b + q thares lots to choose from and a dont know which one i need.......any experts out there ?
I used to fit these occasionally, but not anymore due to Part P.
Screwfix do sell a Drayton 7-day tempus:
http://www.screwfix.com/p/drayton-tempus...mmer/37586
Easy to fit, usually 6 or 4 wires depending on whether there is a thermostat.
Only do it if you are competent and can definitely isolate it before removing the cover.
A year or so I bought a new programmer as I was getting interference on the TV and it was suggested this may be the cause.
It was a Honeywell one so I bought the same make but a current model for easy installation. Wrong - wiring was all different and I didn't want to foc up the new boiler so a local sparky charged me £40 to wire it in.
Cured the TV problem as well !!
just been to b&q and bought new programmer and thermostat...themo is the same and will fit original wall plate.....programmer is updated version which they say will work....going to check drayton website before i fit.....
If you are going to diy make a note of the connections before you start , just in case you have to call in a sparky .
all fitted and working.thanks for all replys....nice and toasty now.the old thermostst was stuck at full throttle so iam hoping my mpg has improved......will check this afternoon  Wink
your missus been sticking therm on full Wink
