... does anyone know the difference between the R1 (1998-2001) Blue Spot rear caliper and the FZS1000 Blue Spot rear caliper - I presume there is enough of a difference between the two for the R1 to be incompatible as an upgrade to the FZS600 (yr. 2000) rear caliper?
The catalogue number for the YZF-R1 rear caliper is 5JJ2580W0000 (yr. 2000)
The catalogue number for the FZS1000 rear caliper is 5LV2580W0000 (yr. 2002 - compatible with 01 to 05)
What issues for fitting an R1 rear caliper Blue Spot to the FZS600?
Thanks.
Upon further research on older threads, it looks like the mounting bolt holes are spaced differently, so not compatible - so, question (partially?) answered ...
Thanks.
