22-11-13, 02:47 PM
(This post was last modified: 22-11-13, 02:55 PM by Frosties.)
Hiya fellas,
As per title, are these any good & a worthwhile investment.
The last few days running up to London & back with the Tiger, I've noticed it getting that little bit slower to turn over each start - to work and from work.
I always run with the headlights on (dual H4's) and have also been using the heated grips each way. Now the battery is about 14 months old & it's charging at 14Vdc so alternator all good. The battery is made by GS and is a CB14L-A2 (short notice buy from local KTM dealer) which meets my CCA of 140A.
Question is - is it time for a new battery or should I be plugging into an Optimate or equivalent every night.
Don't want to buy a new battery @ £50 odd when I can get the below for less money. Orrrrrrrr did I just buy a cheap shite battery instead of a Yuasa?
http://www.bykebitz.co.uk/motorcycle-bat...miser.html
Any advice as always is much appreciated
I wouldn't be without mine, any time either bike is parked up for more than a week or so, it goes on the optimate - essential over winter, the cold just kills batteries, especially if it's got an alarm to power.
But you use your bike everyday, yes? A long run?
Does sound like your battery may be on the way out...
I use my bike daily, with headlights and heated grips on, and i've had my battery a good few years now without issues.
Only time i'll give it a boost is when i'm back on the bike after snow has sidelined me, and i don't really do long runs either, so with that in mind i would hazard a guess the battery is showing it's true colours. :\
Buy a Yuasa. I bought cheaper batteries for my Daytona 675's and they both only lasted about a year and would run down quite quickly when the bikes weren't ridden.
I have an Optimate and it's ace.
When you get a new battery make sure you put it on CONTINUOS charge for 48 hours. This will ensure you get the most life out of it. Ignore it if the seller tells you it's already charged.
Bought my Optimate 2002 & its kept countless batteries trickle charged-should say-numerous bikes-only had to buy one new battery-that was on the Gen 1 thou which had an immobiliser that drained battery in no time at all. Keeping battery fully charged means less risk of damage to starter clutch. One of the best £40 ever spent. :lol
(22-11-13, 11:30 PM)Doddsie link Wrote: Worth every penny. :thumbup
Go to an auto electricians and get them to test battery and earths.
Or perhaps if battery not that old it's in warranty
including ones who like chocolate....
i got one of those ctec things off ebay!!..seems ok?...used it over 3yrs ..
Thanks for all the advice fellas, much appreciated.
Have checked all earths/connections and the bike never gets laid up for more than a week at a time (holiday). 100 mile daily trip!
Sounds like a new battery AND an Optimate - just to top it up over the weekend.
Going for this
http://www.ebay.co.uk/itm/Motobatt-AGM-B...4897.l4275 as it has cracking write ups!
Cheers again :thumbup
Hi Frosties, I got a Motobatt over a year ago now and have had an optimate even longer, would'nt be without either now. Battery is great with no issues as yet and not used the charger on it yet and its on a 97 Diversion 600 with heated grips used when its cold.
Buck
(23-11-13, 10:36 AM)Bigfellabuck link Wrote: Hi Frosties, I got a Motobatt over a year ago now and have had an optimate even longer, would'nt be without either now. Battery is great with no issues as yet and not used the charger on it yet and its on a 97 Diversion 600 with heated grips used when its cold.
Buck ...+1...good choice of batt there  ....after 2yrs still trys to spin engine out of frame :rolleyes better than yuasa!!...
23-11-13, 12:42 PM
(This post was last modified: 23-11-13, 02:05 PM by fazersharp.)
I use a yamaha branded but made by CTECK who also supply jag bently and the like with the same charger/ optimiser it will charge and recover an otherwise dead battery/cell on bikes or car, the yam branded one I have is this one I think http://www.ctekchargers.co.uk/ctek-mxs5.0.php there is a cheeper one just for bikes but I thought this would be usefull for my car too.
EDIT TO SAY
The company says that -------- restores stratified and deeply discharged batteries, unique maintenance charging,
And not as I put it Quote:optimiser it will charge and recover an otherwise dead battery/cell on bikes or car
(23-11-13, 12:42 PM)fazersharp link Wrote: I use a yamaha branded but made by CTECK who also supply jag bently and the like with the same charger/ optimiser it will charge and recover an otherwise dead battery/cell on bikes or car, the yam branded one I have is this one I think http://www.ctekchargers.co.uk/ctek-mxs5.0.php there is a cheeper one just for bikes but I thought this would be usefull for my car too.
I deal with a lot of batteries on a daily basis at work and i can promise you that if a battery is on its way out then no amount of recharging or gadgetry will bring it back to life!
23-11-13, 02:10 PM
(This post was last modified: 23-11-13, 02:21 PM by fazersharp.)
I have added an edit to my post.
I spose what I said is what they want you to think.
Im still happy with it tho as I thought I had compleatly deaded my 14 year old battery last year whilst trying to start it, as it was down to very low volts and on reading this forum back then I understood that a battery that low could not be recovered but the charger brought it back to life and so far so good on a 15 year old battery
Here is that story that the OP may find helpful http://foc-u.co.uk/index.php/topic,1403....l#msg10194 and here http://foc-u.co.uk/index.php/topic,1402....l#msg10180 I did say it did not kick into float mode --but it did after leaving longer, so for me it seemd to do the trick
(23-11-13, 12:40 PM)CRH link Wrote: [quote author=Bigfellabuck link=topic=10803.msg114483#msg114483 date=1385199393]
That'll do for me fellas! Will still get an Optimate............just to try and outspend the wife :lol
