11-10-13, 12:26 PM
Ivanised carbs on Ebay.
13-10-13, 09:32 AM
all well and good but I believe the air intake and box need modifying so would have to know what you are doing before just fitting ivanised carbs
13-10-13, 10:29 AM
(13-10-13, 09:32 AM)fazerblue link Wrote: all well and good but I believe the air intake and box need modifying so would have to know what you are doing before just fitting ivanised carbs I know that Mike cuts about 180 deg of the short intake pipe inside the airbox cover away, but I'm sure he'd be happy to tell you exactly what he does to it. He also ports the carb rubbers on the engine side, but this isn't absolutely necessary. And he fits a freer flowing air filter (K&N, BMC etc). Most of this info can be found in various links on this site too, have a look around. I don't think you'd have any problems doing the various bits required once the carbs are done, the drilling of the carbs is probably the most "sensitive" thing, that you don't want to get wrong.
13-10-13, 10:48 AM
But has the Ivan's kit been fitted to these carbs correctly? If they are not set up the bike will be a pig!! Get it done properly!!!!
« Next Oldest | Next Newest »
