14-09-13, 08:05 PM
Decided to check the sprocket nut and clean out the crud/relube from behind the sprocket cover. The nut is the old 9mm so will need to head to wemoto for the 12mm but the sprocket is solidly on and the threads look ok (phew), the amount of crud was as expected.
When I took the cover off the clutxh pushrod was stuck to the actuator and pulled out by a good 4cm, pushed it back in but it doesn't feel as if it is pushing on the clutch springs just a hard dead stop. Could something have fallen out internally? looking at the parts fiche it isn't obvious if anything can.
Cheers.
Cheers.
The push rod can be pulled out completely (need to watch for the ball bearings though) so no harm in it being removed only slightly. It takes a fair amount of force to push against all 6 of the springs on the clutch (otherwise it would work very well
) so its not out of the ordinary
![[Image: 242673.png]](http://badges.fuelly.com/images/smallsig-uk/242673.png)
![[Image: 174802.png]](http://badges.fuelly.com/images/smallsig-uk/174802.png)
