10-09-13, 07:55 AM
hi all anyone out here got a set of front forks for n r6 ??
want to upgrade my front end
cheers P
cheers P
waters wet, shit stinks !
r6 front forks
10-09-13, 07:55 AM
want to upgrade my front end cheers P
Yes, I have spare 5SL forks.
http://foc-u.co.uk/index.php/topic,7894....l#msg77146 You want to upgrade an FZS600 or 1000?
11-09-13, 10:20 AM
If you mean USD forks, forget it - the front speedo drive / TPS is the problem. Unless you retain the standard unit, I believe it won't rev above 10000 anymore.
The last person to try it http://foc-u.co.uk/index.php/topic,8232....l#msg80600 converted the forks, then quietly disappeared off the forum : I saw his his bike on ebay a while back, I assume it was because he couldn't get round the problem. RWU R6 forks may be a more realistic option as they are more similar to standard, but AFAIK only 1 person (in Japan) has made the transplant with the standard speedo retained http://foc-u.co.uk/index.php/topic,7561....l#msg72875
13-09-13, 11:58 PM
I however have a pair of Thundercat forks which I bought about 4 years ago and never used
The Frying Scotsman
« Next Oldest | Next Newest »
