Oh dear!
Well, as i stated in a previous post, the bike needed to go to the Dyno man to have the new inlet rubbers fitted and the bike to be set up.
So, yesterday dinner, i took it over and a mate brought me back home, Dyno man phoned me this morning to let me know that number three cylinder has no compression at all, in fact he can feel it coming back through the airbox and the silencer, it's that bad.
His suggestion is either to remove the head and check for bent valve stems and if they are ok, then grind all the valves in.....or, put it back together and stick it on ebay, not a nice thing to do but somebody did it to me, so hey-ho!
So at the moment, i'm waiting for him to get back to me later on this evening, he has other bikes in that the owners obviously want sorting but if one of them isn't too much in a rush, then he can do mine sooner.
If not, then it could be a few months before he an get round to stripping the head off it.
Of course, if i had a garage, then i would strip it myself but i haven't, so i'll just have to wait and see what he says this evening.
I sometimes wonder if it's all worth the bother, unfortunately it is, after 40+ years of biking, it isn't something you can just give up on, is it?
G ; )
Life's a long song....
The job isn't too bad. It can be a little time consuming, but its methodical - do you have any tools at all? If your mechanic gets the head off for you, you could probably take it home and grind the valves yourself Smile
do you have a friend wth a garage....this job is not hard to do just a bit time consuming....the fact the mechanic can feel compression back through the air box tells me the problem is with the valves and not cylinder/piston/rings problem....
Well believe it or not, i've been stripping engines, gearboxes et al, on all sorts of vehicles since my early teens, i've owned a bike shop and a breakers over the years, so i'm no stranger to the infernal combustion engine and it's problems but to be honest, after a 12 year lay-off from bikes, so i could get my studio up and running, i only got back into bikes in 2008, when i bought a Ducati Monster 900, then a 2008 Triumph Thruxton 900, which to be honest, didn't really need much fettling in the time i had them, although i did completely strip the Monster and re-build it in 2009, that was in a mates very large workshop, which he doesn't have any more, as he's move away, which i thought was most inconsiderate.  Wink .
Kev, who owns the Dyno business, has a reputation spanning over 25 years for getting the best out of both road and race bikes and yes, of course i am capable of doing the work needed on my bike but the problem is the workload in the studio, plus somewhere to actually work on the bike.
I could bring the head home and work on the valve grinding but it would be very intermittent.
STOP PRESS:
Kev has just phoned me to say he's removed the head, so i'll try and get over later on this afternoon and see what the damage is, mechanically, financially and more importantly...Physiologically!!
:eek .
I shall return!
G ; )
sounds like you have found the man for the job.....interested to see the outcome  Smile
Hope you can get it running again BluePrintZ...would be a shame to lose you from the forum so soon after you got here.
(05-09-13, 06:37 PM)nick crisp link Wrote: Hope you can get it running again BluePrintZ...would be a shame to lose you from the forum so soon after you got here.
I'm worried about losing another 600!!  :eek :'( :eek :'( :eek :'(
The Deef's apprentice
Christo, if you don't cheer up soon, I'll strap you into that trailer of yours and push you onto the ferry myself!  :lol
(05-09-13, 07:10 PM)ChristoT link Wrote: [quote author=nick crisp link=topic=9736.msg99403#msg99403 date=1378402650]
Cristo, gimme a couple o weeks & ill have some 600 morale boosting photos up to show that they can rise again.
It' coming along nicely now, only the light electrics to be done.
Nick and Christo: I have no intention of getting rid of the Fazer, although admittedly the initial news from Kev did cause a slight wave of depression, as it would.
The guy is a genius and he said it highly unlikely to be terminal damage, at worse he feels it could be a bent valve but until i speak to him tomorrow, who knows?
When he first gave me the news yesterday, i did mention that the bike went like split shat, his reply was "imagine what it will be like when you get it back sorted"!!
So i'll keep everything crossed and hope for a favourable outcome.
G ; )
(05-09-13, 07:16 PM)nick crisp link Wrote: Christo, if you don't cheer up soon, I'll strap you into that trailer of yours and push you onto the ferry myself!  :lol
Well, I do need to get the trailer down to Portsmouth...  :lol :lol
Why not weld your bicycle to it? If it's too heavy to ride, you could rig up an electric motor.  Wink
Hahaha, I'll give you a hand Nick Wink
(05-09-13, 07:40 PM)nick crisp link Wrote: Why not weld your bicycle to it? If it's too heavy to ride, you could rig up an electric motor.  Wink
I have! But not cycling the bugger from Andover to Porstmouth!
Rest easy you two - Fireblake has very kindly offered to tow the trailer to the terminal for me - thanks, man I owe you!  Smile
I hope you can get that sorted out George, you're not having a lot of luck with that bike at moment.  Sad
(05-09-13, 10:13 PM)J_Dub link Wrote: I hope you can get that sorted out George, you're not having a lot of luck with that bike at moment.  Sad
I'm sure it will be fine once Kev has sorted it, i'll know by later on this afternoon John.
Just one of those things mate, i was spoilt with the Monster and the Thruxton, so it was probably my turn to get one that needed a bit of work doing on it.
I'll be up your way on Monday for a few days, so i'll give you a shout at some point.
G ; )
Just had a call from Kev the Dyno man, asking if i've put any kind of coolant in the system.
It appears that someone has put something in that doesn't look like any type of coolant that he's seen before.
He said it's light brown in colour, smells more like a releasing agent.
Deffinitely not oil leaking into the coolant.
G ; )
Someone else had some sort of weird oil in their coolant as well... maybe people are getting confused between liquid and oil cooled engines :|
Could it be someone has put in stuff to flush the system and just either forgotten about it or not cleaned it out properly... or even the coolant has maybe just never been changed... Hope that's not a silly suggestion...
Chris
[Image: 208008.png]
UPDATE:
I've been visiting family and friends up in Lancashire last week, including FOC member J_DUB, who i've known for a few years, was good to see you and the family John.
Anyway, whilst up yon, i got a call from Kev the Dyno man, asking me to pop in to his place when i get home, which i did last Friday afternoon.
The head was still off, because he wanted to show me what he had done to it, plus some pics he had taken from when he stripped it, (i'll get them off him and post them on here when i get the bike back, so that you can all gasp in amazement...or not!).
All of the valves were coked up badly, cylinder no3 was showing exhaust gas blowback into the inlet ports, which means the valves were sticking open, as he said, which explains the lack of compression on that cylinder.
There was also a largish pock mark on the valve seat (i forget which one) but he's ground all of the valves in and cleaned those and the piston crowns, which were also badly carboned up, the cylinder bores were ok.
The head gasket is being replaced (obviously) and new valve stem seals fitted, might as well do those while the head is off, they aren't that expensive.
By the time i ride the bike home, probably later on this week, the final bill will be around the £500 mark, i know it sounds a lot but he is one of the best and the bike will be 100%.
As i mentioned, i'll post the piccies and the Dyno sheet when i get them.
G ; )
