18-08-13, 08:23 PM
Hi Guys, another question from me I'm afraid :/
So I got my old cam chain swapped out for a new split link one, and everything back together, and the bike runs!
Problem is, it doesn't run very well
It just doesn't accelerate properly, and barely pulls at all in anything other than 1st-3rd.
Obviously to get the new chain in, I had the carbs off to get the tensioner out, so I'm wondering if maybe I've done something wrong when I've re attached the carbs? All the cylinders seem to be firing, the sparks are pretty much new and the leads are fine.
Does anyone have any suggestions as to what to check next, what might be a likely cause or just general comments? Or am I better at this stage to just take the thing down the local garage and have a professional look at it?
Thanks for any info people can throw my way!
Harry
It just doesn't accelerate properly, and barely pulls at all in anything other than 1st-3rd.Obviously to get the new chain in, I had the carbs off to get the tensioner out, so I'm wondering if maybe I've done something wrong when I've re attached the carbs? All the cylinders seem to be firing, the sparks are pretty much new and the leads are fine.
Harry
......but if after checking its ok have a look at the carb rubbers on the air filter side,they can fold over when pushing the carbs on and its hard to see if they are fitted correctly
