front piston seals
ok im just about to rebuild my front calipers the problem i have is which way do the seals go round? the haynes manual doesnt say? the pressure seals don't look square
Wider lip goes on the inside of the caliper, if you put your finger in and scrape outwards you should feel a lip.  If you put them in the other way round the fluid will just push past the seal and escape.  Delboy does a good rebuild here and explains it well. Delboy's Garage, Motorcycle Front Brake Caliper rebuild Part 1.
Eagles may soar, but weasels don't get sucked into jet engines...
