Just fitted pc111 and need help
Installed pc111 no probs but was second hand of eBay and had been mapped with his mods,I've downloaded the stock map as my bike is a stock bike,just a worried about how lean it is now because it says -8 .power commander obviously know what there doing just don't want to damage my bike being too lean, has any run there bike on stock settings or does anyone know a bit about pc111 that could help?
If your bikes stock, why the hell have you fitted a pc? It doesn't need it!
[Image: 850481.png]
I was told it would sort out snatchy throttle. mines an2006 and rode my mates same bike and its a different bike, I could be completely wrong
Aah, its an 06. That says it all with the throttle snatch. Not too sure about the pc  sorting the problem out, thought that was the fuel cut off on closed throttle over 4k. I've heard an ivans FCE sorts that out. There might be a map that does it, check the fz1oa site, there's loads of maps on there.
[Image: 850481.png]
I doubt you will do any damage to an engine, get on it and thrash it :b
Spoke to dyno jet technician today and I had the us stock map so put European stock map on and found O2 eliminator plug in the dyno jet box aswell. Bonus!!!!
Just been for a ride (only 10 minutes) and it feels like a different bike.a great bike made better
Also i was advised to unplug the connector to the sensor in the exaust, whatever it does and leave it unplugged,under the tank.Seems to work fine.
