Leaky seam
I was giving my bike it's yearly bath earlier and noticed air leaking from one of the seams, can I reseat this myself or do I have to take it to a fitters?
thou shalt not kick
Have you got an inflatable bike ?
Oops, should have mentioned it's a tyre seam
thou shalt not kick
This normally is caused by corrosion on the rim. You might be lucky and let all the air out and reinflate but both times I have had this (gsx600f and once on the fazer 1000 before I power coated them) Its ment tyre off, sand paper it smooth and refit/ballance tyre.
[Image: 82304.png]
Well that's not what I wanted to hear but thanks for the info. Any ideas how to do this myself or is it a garage job? I've seen a guy use a G-clamp to push the tyre off the rim when he fitted me a new valve...
thou shalt not kick
Took it off and went to a garage, serviced my back brake while i was at it. For £5 it wasn't worth wrecking a nearly new tyre
thou shalt not kick
when I've had car tyres leaking round the rim, the tyre fitters hit them with a very big rubber mallet, don't know if it's a good idea hitting the side walls of a bike tyre?
To be honest even if they were charging 4x more I'd still pay, I've not got any tools for tyres and I'd rather not mess one of them up
thou shalt not kick
