I thought I would spray my standard rad cover on my gen one fzs 1000 but disaster struck
both the mounts have snapped off :'( the rad
so my question
1/ which stainless steel rad covers will fit under the side cover mounting screws ?????
2/ when fitting a stainless cover I take it u dont need old one under it ???????
What have the mounts snapped off ? The radiator itself or the radiator cover ?
If the radiator is ok there are loads of options out there that mount to the original, standard mounting points. I have a Beowulf cover myself which i am happy with.
If you are looking for a radiator cover that mounts anywhere other than by the correct mounting points then i can't really help you. Having said that, most things can be modified.
