Would you buy this?
Hi guys, just about to finally fix my forks. I've got all of the oem seals, clips, bushes etc ordered from AJ sutton but the OEM tube is quite expensive. I found these on ebay, what do you guys think?
http://www.ebay.co.uk/itm/YAMAHA-FZS600-...2c6eb6546a
http://www.ebay.co.uk/itm/YAMAHA-FAZER-6...4ac154ac34
What is wrong with the ones you have?
Later
Sorry should have specified, I only need one it's the left side as on close inspection I have noticed that there is some pit marks / scratches in the fork travel area which are likely causing the seals to fail (new ones have failed twice). OEM are £145 each just for tubes which is a lot of money, these look quality to me but just wanted to get some second and third opinions really. The right tube is fine, the 2 links are only there as choices / options but one is all I need.
Get it/them repleted  Smile
Later
