mine looked like this! :eek
had to double check if it was water cooled or not, it looked like oil and smelt a bit like burnt caramel.
Oh dear, that is oil, that ain't good at all..... :eek
05-05-13, 04:41 PM
(This post was last modified: 05-05-13, 04:49 PM by markaboot.)
thought so, doing a compression test now.
edit: no i'm not because i don't have the right adapter
look grim whatever it is. try taking one of the lower hoses off and run some water through it and see what comes out
05-05-13, 05:12 PM
(This post was last modified: 05-05-13, 05:13 PM by markaboot.)
i flushed it all today, fresh water in. will run it a couple of times then flush again and put antifreeze in.
if was oil would i not have mayo in the radiator cap or worse on the oil cap?
i think its probably just really old coolant and well overdue a change.
05-05-13, 05:21 PM
(This post was last modified: 05-05-13, 07:33 PM by unfazed.)
Are you sure you didn't open the oil plug instead instead of the coolant bolt :'(
Not necessarily a compression problem, more than likely a water punp issue
05-05-13, 05:47 PM
(This post was last modified: 05-05-13, 05:57 PM by darrsi.)
I have a feeling this could be connected to your rattle?
And it wouldn't matter if your coolant was 10 years old, it still wouldn't be that colour or texture!!
Three posibilities Water pump , head gasket or oil cooler .
Most likely the water pump mechanical seal if there is no coolant in the oil.
(05-05-13, 07:35 PM)unfazed link Wrote: Three posibilities Water pump , head gasket or oil cooler .
yea oil looks ok from looking in the cap and window. very slight mayo on the cap thread, that normally i'd put down to condensation, im talking minimal amount, tiny tiny.
but then oil floats on water so any water would be in the bottom.
the coolant deff had an oily smell and feel on my fingers, but i've never seen oil and water mix without turning into mayo.
Is this the same bike with the rattle when hot? It is certainly pointing to the pump on both posts.
The noise sounds like the impeller knocking off the casing due to a knackered bearing which has damaged the seal.
Just read that the bearings can go on the impeller part of the pump.
I'd get your ear towards the water pump and get someone to rev the engine a little.
I do believe thats what I said, water pump problem, if you read both threads
quiet when cold, rattles like mad when warm ??
what colour was your coolant last time you changed it?
They are related :wall
and no you cannot get bearings or seals for it, the complete pump needs to be replaced.
Since it does not happen to often it is worth taking a chance on a second hand pump.
06-05-13, 06:36 AM
(This post was last modified: 06-05-13, 08:09 AM by darrsi.)
(06-05-13, 12:17 AM)unfazed link Wrote: I do believe thats what I said, water pump problem, if you read both threads
I know, and i do believe that i remember you posted as i was typing my answer at the same time.
And yes i know that he has the same name, the same bike, and i've been reading and commenting in both threads too, and i never mentioned buying bearings or seals for it, i was trying to pinpoint exactly where the actual fault was for starters!
Have a read and you'll see for yourself! :wall :wall
Did we get a bit tiddly last night perchance? :b
Darrsi
Time for you to start reading the posts properly. :eek
You must be having one of you DARSSI moments :pokefun
Go back an read them again. :z
06-05-13, 09:46 AM
(This post was last modified: 06-05-13, 02:55 PM by Gnasher.)
(05-05-13, 04:18 PM)markaboot link Wrote: mine looked like this! :eek
![[Image: 944956_10151483349883725_1121603211_n.jpg]](https://fbcdn-sphotos-d-a.akamaihd.net/hphotos-ak-prn1/944956_10151483349883725_1121603211_n.jpg)
I've just seen this post, how long have you owned this bike?
Never seen this of on a Fazer before but on other bikes mainly race engines, somehow the coolant could been lost due to a leak or after doing some work i.e. loose pipe etc. I've also seen it where debris has entered the system after major work or using an old watering can which jams the impeller and buggers the bearing. The coolant is then lost through evaporation, oil enters via the buggered bearing/impeller shaft the bike is now oil cooled I will work but not for too long!
Fully and semi synthetic oil is that good today an engine can run with almost no loss of performance for a limited time with no coolant. Bit of history here during WW2 most US carrier based aircraft engines where big radials, radials were mainly air cooled and preferred over water cooled engines at the time as they didn't have cooling systems that are venerable do battle damage. The Pacific war was by definition fought over long range over water the planes had to get back to the carrier or ditch in the sea, risking loosing the pilot.
Battle damage often meant damage to engine oil tanks and possible total oil loss so they devolved oil additives (PTFE forerunners) slick 50 and such like, these would enable an engine to run without oil. Which would keep the plane flying get the all important pilot/s back the the carrier the engine would be shot but they had plenty of them.
You need to do a major strip down to see what is going on with this engine or just get hold of a good second hand engine there are plenty out there.
Later
Just to answer the thread question, on both my Fazers the stuff that came out was luminous green and had the consistency of water. The stuff that's gone back in is more of a burnt orange colour - picked it up at Halfrauds
I just read somewhere else that "Bars Stops Leaks" which is a different brand of RadWeld can make coolant oily over a period of time.
If it could reliable change water into that sort of oil I'd be half tempted to put it in the engine haha :lol
In all seriousness though, that doesn't look as though its been changed / altered, it looks like it literally is and always has been oil
