Replaced steering head bearings. But......
Hi all,
Just replaced my steering head bearings in my gen 1 with a kit from Mark ( Marksman ). A nice looking taper set but...All went well until I tried to use the stering lock. The hole in the frame and the lock plunger do not now line up. The plunger is now approx 2mm to high to engague with the hole. Bearing set is fitted correctly. Options I suppose are dremmel the hole bigger, drill the sheer  bolts off and spacer the lock assembly down or reduce the diameter of the plunger.
Anyone else had this problem?
I not sure but surley it should be like for like replacment size wise so no adjustment should be needed .
is it possible something has not gone back together correctly a spacer missing or in the wrong place ?
Hi Snapper, yes would have hoped it was a straight swop. The originals are captive ball, the new ones are taper roller. There must be a slight difference somewhere.
I am confident its all back together properly but as it has to come apart again to carry out mods as above I will double check.
Just wondering how others have got on,I would have bought genuine parts if I know what I know now.
yes maybe a slight variation but 2 mm is huge ! :eek
I would say wait till others or marksman reply before grinding cutting anything , but in all honesty I think somethings wrong , what? I have no idea
Thanks for you input Snapper, noted.
Think I read something that tapper bearings often need to be retightend after a little use. Not used a set so not sure, just remember something about it.
[Image: 82304.png]
(28-04-13, 06:51 PM)sirgalahad3 link Wrote: I would have bought genuine parts if I know what I know now.
What exactly do you know now?
All we know from reading your post is that the finished installation isn't in your eyes as expected or satisfactory.
Maybe if you were to post pics of the installed bearings we could give a second opinion as to the merits of their fitment or suitability for use.  Wink
Had lots of bearings from mark before without issue. Though not that set.
[Image: 82304.png]
I think if you go back and look again, you will find the 2mm is not the bearings. I would guess that you havn't fully seated them, but without some pictures, I am only guessing.
Hi,thanks Dek but I didnt as ask for the merits of their fitment or suitability for use, just if anyone else had had this problem...
Thank you everyone else.
either you've not seated them fully, or you've got the wrong bearings in there mate - there's no difference in the sizes between ball and tapererd needles if they're the right ones and have the neccessary races!
i had this prob when fitting marksman bearings, my prob was cause i didnt seat the lower bearing correctly .
several smacks with me tickleling stick sorted it.
ps i have r1 forks on that one
the down side was me tin hat spacer needed a bit shaving off
Thanks guys,sorted now. On the original setup there is a rubber washer between the adjusting nut and the locknut. I reused this washer . It seems if you take out the rubber washer from between the nuts it drops the top yoke down enough for the steeing lock to engague properly. Am not sure what the rubber washer does,never seen one there before but all seems well now. I will keep the washer just in case!
Glad you got it sorted.
The rubber washer is only there to enable the top locknut ( normally only handtight) to be able to be line up easily with the torqued nut so that the locking washer can be fitted. The top yoke then presses down on the locknut preventing it from slackening off. I can't see it making a difference as long as the top nut is tight to the yoke
The lower adjuster nut is the one that pulls the steering races together to the correct torque.
The rubber washer between the two nuts is there solely to prevent the top (locking) nut from coming undone by allowing some leeway to position the tag washer so that it engages the slots in the sides of the two nuts.
Removing the rubber washer would not have caused your problem.
Did you follow the torque/re-torque procedure to fit tapered bearings?  The first one pulls all the bearing races into place fully, the second - lower torque - setting takes out the freeplay but allows the bearings to turn freely.
Marksman supply the correct bearings for this bike so I suspect you hadn't seated them properly first time around. Smile
Dek: good explanation as to what rubber washer does,thanks. Lucky for me the 2 nuts lighned up just right without it for the lock washer to seat easily.
Mike: removing the washer cured the problem,it did not cause it! With the washer in place the top yoke sat too high. I can only assume with the marksman kit you just do away with the rubber washer.
Whilst Marksman supply correct fitment bearing for most places on the bike I would be interested to hear if anyone else manages to get one of there head kits to fit with the steering lock working using the rubber washer.... Highly possible but we will see.....
I have the Marksman bearings in mine and the rubber washer, too.
Think about this logically. Smile  The washer is compressible, it serves no purpose in determining the overall relationship between steering stem, bearings and bearing tracks.
The only possible explanation for your problem is that the bearings aren't seated correctly.  You've chanced on what you think is a solution but I believe something still isn't right.
Hi Falcon.      Was that with the original fazer forks or your new R1 set up, IE did you use the rubber washer with fazer set up and marksman bearings?
I am wondering if the top lock nut wasnt tightened down enough to fully compress the rubber washer,leaving the top nut too high.
Anyway the plan now is to ride it while the so called good weather is here as it is, I will probably strip it again in the winter and recheck etc.
Doesn't matter which forks are fitted because the steering stem is the same and so is the headstock in the frame. Smile
The rubber washer serves absolutely no part in establishing and maintaining the relationship between steering stem, bearings and top yoke.
Hi Falcon,all accepted but did you get your steering lock to work on you standard forked fazer with rubber washer and marksman bearings fitted....or did you only fit marsman with your R1 set up which I understand has no stering lock?
Thanks.
