Fxxxing thing,
I've serviced it, took it out and put it back in (oo err misses
now I'm considering junking the whole shebang.
I know the purists will frown in tuning fork disappointment but I've been told by a life long R1 fan that it don't make that much difference.
the bikes a 2001 gen 1 with 15000 miles under its wheels.
Fines are cheaper than front tyres!!
OMG! If that geezer in Spain sees this he'll be spitting his Rioja into his paella. :eek
(26-04-13, 08:32 PM)DekF link Wrote: OMG! If that geezer in Spain sees this he'll be spitting his Rioja into his paella. :eek
:lol
I think you'll regret it. Mine didn't have an Exup in when I got it and in my opinion the best thing I ever did was fit one. Depends where in the rev range you live though. If you rarely go below 7k you'll be fine.
Blessed are the cracked, for they let in the light.
I've ridden one with one without and my brothers which is ivanised and i gotta say for pure grin factor keep ur exup and ivanise it mate. U wont ever regret it. They can be problematic but there is so much resource here u shud find an answer in past posts to any probs u may have. If not the falcon is in england and i'm sure if u go fer the ivans mike would help u with ur valve. Oooer mrs lol
Just flapping about on this stagnant little pond on the outer rim of the internet.....yup.... :-))
"exup belongs with the industrial revolution"
in that it is over engineered built to last and still working more than 100yrs after it was made?? :b
Tommo
Each to their own, like it or loathe it. I'll keep mine as long as it works and will tinker with to keeping it working.
Mickey
27-04-13, 07:26 PM
(This post was last modified: 27-04-13, 07:31 PM by Exupnut.)
"Exup belongs with the industrial revolution"
True i suppose but these bikes r retro and to some extent the teck but its there for a reason. Minus the emission laws of that era this bike would have been foccin A. . Mike and mr ivan himself just aims to get round that with this kit and give people a bike as it should have been in the first place. FOCCIN BLISTERIN!!! Ahem....
Eight minutes is all it takes to service this mechanical valve. Keep it working and it'll give you years of endles yeeehaaah.
Eight minutes every other month....
.... Privided you can get the bolts out
8 minutes is all it takes to bin this heap of mechnical crap, then Ivanise the carbs and modify the air intake. Afterall isnt that what Amal carbs (different size jets and throttle valves ) and the likes of K&N filters with their replacement air filters allowing standard engines to be uprated to a higher performance?
As previously stated " same old faces " there is none so blind as those who will not see.
my exup valve had been broken for a few years. One of the bolts for the cover had snapped and i couldn't drill it out. So with two bolts holding on the cover / housing it didn't go on flush so pinched the valve off centre and jammed it.
Anyway, end result was the valve wouldn't rotate so i just removed it. I took the exhaust off to paint the engine and tidy up the bike as i've done 30,000 miles now. With the bolt removed and a helicoil fitted at a local engineering shop i could refit the valve.
The result - OMFG :eek [size=78%]- [/size]i could not believe the effect, it was like a new engine was fitted. I thought there would be a minor improvement and had forgotten what the bike was like with the exup working.
I'd always keep a *working* valve - also i've been Ivanised (by the Mike incidentally)
[ although i will be posting a question about valve operation as it doesn't seem to be resetting to the fully closed position - but the performance is night and day ]
