How to set fzs clock adjustment
Hi anyone know how to set the clock on a yamaha fazer fzs 600
Clock mode
To change the display to the clock
mode, push the “SELECT” button.
To change the display back to the
odometer mode, push the “SELECT”
button.
To set the clock
1. Push both the “SELECT” and
“RESET” buttons for at least two
seconds.
2. When the hour digits start flashing,
push the “RESET” button to set
the hours.
3. Push the “SELECT” button to
change the minutes.
4. When the minute digits start flashing,
set the minutes.
5. Push the “SELECT” button to start
the clock.
NOTE: @
After setting the clock, be sure to push
the “SELECT” button before turning the
main switch to “OFF”, otherwise the
clock will not be set.
http://foc-u.co.uk/index.php?action=downloads;cat=2
Many thanks
(25-04-13, 09:08 PM)karlo link Wrote: Clock mode
button.
To set the clock
seconds.
the hours.
change the minutes.
set the minutes.
the clock.
NOTE: @
Many thanks.. cheers
