24-04-13, 09:55 PM
How much should front brake pads cost?
24-04-13, 10:01 PM
DO NOT scrimp on brake pads, it's just a dangerously false economy.
SBS seem to be the most popular choice on here, with very good references, and they're not even expensive oddly enough!
24-04-13, 10:03 PM
I'm not working so the problem is money is tight. Will those do till I get some money for them?
24-04-13, 10:13 PM
The reason I am asking is because I am having a problem with my front brakes. They are making a awful sqeaking/crunching noise. I checked the pads and here they are. I cleaned them and it's is still there.
http://imgur.com/MD8gHFY http://imgur.com/nSuE1xt
24-04-13, 10:40 PM
What are we looking at? Is there something embedded in the surface?
Have you tried sandpapering them?
24-04-13, 10:42 PM
24-04-13, 10:48 PM
Did you put a bit of copper slip on the backing plate of the pads? That's supposed to stop them squeeking a bit.
As for the crunching... can you explain it more? Everything tightened up ok? Chris
24-04-13, 10:49 PM
The chances are the calipers need a good clean up too.
If you want send me a PM with an address and IF i have some pads in my garage i'll send you some in the post to get you by for a while. I went through a load of pads when i had my "juddering" problem, and "think" i kept some. I can let you know in the morning if i have or not? If i do i'll take them to work and can post from there for next day delivery.
24-04-13, 10:55 PM
You are very kind Darrsi 8) Good on you sir!
Chris
24-04-13, 11:06 PM
The pictures seem to indicate that there is loads of life left in those pads imo
I'd suggest your problem is elsewhere. ChristoT recently had an issue with his front brakes squeaking a lot so when he was round mine the other day, we removed the callipers, removed the pads, put some copper grease on the back and reassembled and now the squeak is completely gone. You can get a massive pot of copper grease for less than one of those cheap sets of pads you found
24-04-13, 11:06 PM
(24-04-13, 10:48 PM)Chris link Wrote: Did you put a bit of copper slip on the backing plate of the pads? That's supposed to stop them squeeking a bit. Everything tightened up as it should. The crunching noise/feeling comes through the handlebars and give me a tiny wobble. Tires are only 2k miles old.
24-04-13, 11:07 PM
(24-04-13, 11:06 PM)Dead Eye link Wrote: The pictures seem to indicate that there is loads of life left in those pads imoordered some copper grease last night, should come tomorrow.
24-04-13, 11:08 PM
(24-04-13, 10:49 PM)darrsi link Wrote: The chances are the calipers need a good clean up too. Thank you so much, I'll send you a PM now.
24-04-13, 11:09 PM
It's certainly a cheap option to try out first and it won't do any harm
As I said before, the pads look like they have a lot of life left and they don't appear to be unevenly worn so its likely that you just need to give the them a bit of a greasing on the back of the pad and to maybe clean up the callipers a bit. Also, put some grease on to the pad retaining pin
24-04-13, 11:12 PM
Was about to say, clean up the pad pins really well and lightly copper grease them so the pads can slide properly.
And make sure there's no deep grooves for the pads to get stuck on.
24-04-13, 11:14 PM
(24-04-13, 11:09 PM)Dead Eye link Wrote: It's certainly a cheap option to try out first and it won't do any harmAs I said before, the pads look like they have a lot of life left and they don't appear to be unevenly worn so its likely that you just need to give the them a bit of a greasing on the back of the pad and to maybe clean up the callipers a bit. Also, put some grease on to the pad retaining pin [/quote] Will do, copper grease should arrive tomorrow, I'll do it then. Again, thank to everyone for the advice and a big thanks to darrsi
25-04-13, 12:21 AM
Just noticed that no one has actually answered the thread question.
Depends on the pads. But decent pads seem to go for about £12-£18 a set depending on where you buy them from and the make etc. The SBS Ceramics I like are about £15-16 a set
25-04-13, 12:33 AM
Can you afford to buy cheap brake Pads????, I am inclined to spend a little extra for recognised brands for shear piece of mind.
I would suggest you remove the wheel and check the wheel bearings.
25-04-13, 12:39 AM
(25-04-13, 12:21 AM)Dead Eye link Wrote: Just noticed that no one has actually answered the thread question. Opinion on these? http://www.ebay.co.uk/itm/Yamaha-FZS600-...43a1a43307
25-04-13, 12:39 AM
(25-04-13, 12:33 AM)unfazed link Wrote: Can you afford to buy cheap brake Pads????, I am inclined to spend a little extra for recognised brands for shear piece of mind. It's defo the brakes. Sometimes I have to pump them on once or two mind. Also checked for any leaking and there is none, the piston also move freely. |
« Next Oldest | Next Newest »
![[Image: 208008.png]](http://badges.fuelly.com/images/smallsig-uk/208008.png)
![[Image: 242673.png]](http://badges.fuelly.com/images/smallsig-uk/242673.png)
![[Image: 174802.png]](http://badges.fuelly.com/images/smallsig-uk/174802.png)
