digi gear indicator
Mine has stopped, no digits displayed, where will it be wired to to remove it?
Is the answer not as obvious as following the wiring from the back of the display?
Sent from my Nexus 7 using Tapatalk 2
My digi is wired into the loom behind the clocks, take your screen off and you should be able to see it.
Sent from my HTC Sensation Z710e using Tapatalk 2
Not that easy to follow the wires,
The screen on it is blank, dont know how reliable these things are, its a well known make too.it was fitted when i bought it,i am just worried that it could cause problems left joined up.
If it hooks up in the dash cluster then i guess i could unhook it.
Might be a plug and play like mine. Unplug then re join the normal conectors
If not then it will be hard wired in, still simple to remove though.
[Image: 82304.png]
